Old 09-25-2015, 06:41 AM
TXFlyGuy TXFlyGuy is offline
Default Brass fuel line fittings?
Is it ever acceptable to use solid brass fittings (hose barbs / T-fittings) in a fuel line? We are having a debate...one friend and RV-8 builder says NO! And another builder claims it is very safe.
Who is correct?
Old 09-25-2015, 06:53 AM
Mike H Mike H is offline
Lots of vintage aircraft use brass fittings in the fuel system. What specific application in the fuel system are you referring to?
Mike Hammond
A&P IA PPL ASEL
RV-14A kit S/N 140170
Old 09-25-2015, 07:03 AM
Coming out of the fuel tank, between the fuel pre-filter and the fuel pumps. A brass T coming off the filter, then going to the pumps via a hose barb. All safety wired.
Old 09-25-2015, 08:03 AM
rv7charlie rv7charlie is offline
I suspect that the bigger ones are what caused their bad reputation; the wall thickness vs total size tends to suffer as they get larger. Brass wouldn't scare me if I could make sure it wasn't 'stressed' by static loads, and vibration wasn't an issue. Using one on an engine does get a little more dicey. A fried just lost a Cessna 195 to a brass 'L' in the oil system (a certified part, BTW).
If you're really concerned, you can probably get the same part as an A/N fitting in your choice of materials, or at least a stainless plumbing part.
Charlie
Old 09-25-2015, 08:07 AM
Charlie
As this is well back of the firewall (at the fuel tank), I do not think it will be an issue. The fittings are 3/8".
Old 09-25-2015, 08:13 AM
It's not what I prefer to use but I does not sound like a safety of flight issue either. Lots of vintage and very light aircraft use hoses with barbed fittings and clamps. I prefer to use flared fittings.
Mike Hammond
A&P IA PPL ASEL
Alot of planes had brass, but they also used rubber push on hose too. Several LSA aircraft still use it. Costs less than AN hardware, and is easier to install.
But---its still brass.
Tom
Ridgeland, SC
Old 09-25-2015, 08:19 AM
Is there something inherently dangerous about brass mixing with fuel?
Old 09-25-2015, 08:32 AM
krw5927 krw5927 is offline
I've always heard to stay far, far away from hose barbs, clamps, and the like in aircraft fuel systems. Also that fuel system issues are a primary, if not leading, cause of "eventful" first flights. Please be careful here. Sticking to the most common fuel system materials and the plans is one way to ensure reliability.
(Note that I'm not saying don't do this, you'll fall out of the sky, or anything like that.)
Kurt W.
RV9A
FLYING!!!
airguy's Avatar
airguy airguy is offline
Brass and fuel? No, no problem there - just that the brass is not as strong as a steel or aluminum AN fitting under vibration.
