Originally Posted by rightrudder
Good info, Derek. Am I right to think that with a little less pitch, take-off rpm will be higher and climb performance a little better than, say, a 70/72?
Yes, in fact I think you will be quite pleased. What was intriguing to me with the Catto was that even though I thought it was under pitched at altitude, I never thought so on the ground. My static run-ups were spot on, 2150-2200 if i recall, and climb was good to. I could just never firewall it, unless i was REAL high. Your ability to run lean of peak (with your FI), effectively reducing full throttle HP, might just make this prop a perfect fit for you.
I think BruceH runs lean of peak a lot on his cross countries, maybe he can chime on whether or not it allows him to firewall it?
Running full throttle on a carb produces more even fuel distribution, (butterfly straight up and down) but if your under pitched you can never do that unless you're really high up....
Derek Hoeschen
EAA Tech Counselor
RV-9A #92103 - N803DK
G3X, Superior XO-320, Dual Pmags, Catto 3B
www.mykitlog.com/dbro172/
1974 Bellanca Super Viking - N16AW - Flying
RV-8 #83565 - N184DK - building
1968 Mooney M20C - N6801N - Sold
1956 C-182 - N744W - Sold
