09-22-2015, 01:15 PM
RV-12 fuel tank ? how much tank sealant required?
About to begin assembling the RV-12?s fuel tank. It is one of the newer tanks without the site gauge on the side and has the holes for Moeller fuel gauge and the new fuel tank venting method. Originally, I was considering ordering a handful of the MC-240-B1/2 1 oz kits of fuel tank sealant from the Van?s site figuring it could be used on the fuel tank and the remaining kits used on some of the other locations on the RV-12 which require sealant. However, just discovered the one ounce kits only have a 30 minute work time, which surely is not enough time to assemble the whole fuel tank.
I see there is the MC-236-B1/2 Tank sealant in a 3.5 ounce size with a 2 hour pot life and was wondering if anybody has used it to assemble their RV-12 tank? If so, is 3.5 ounces enough material to get the job done and can it be completed within the 2 hour limit?
I don?t have a gram scale so do not want to purchase a quart which requires weighing out the material and catalyst.
Comments appreciated ...happy building,
John
www.dogaviation.com
RV-12 Wings, Empennage, Fuselage, Finishing, Avionics and Powerplant kits all completed
Now Flying!!
Donation paid until September 2021
09-22-2015, 01:28 PM
I used the quart kit. I didn't have a gram scale either but got one from Harbor Freight pretty inexpensively. Ended up using the gram scale for other stuff anyway (fibergass mixing, etc.).
Tom
Port Orange, Fl
EAA #51411
RV-12 N121TK ELSA #120845; first flight 06/10/2015; 700 hrs as of 02/2020
RV-12 N918EN ELSA #120995 Eagles Nest Project; first flight 05/18/2019
SPA Panther N26TK; First Flight 03/13/2020
09-22-2015, 02:39 PM
My experience (s)
The 3 1/2 oz are very good. You will be better off not trying to do it all at one time. Buy 3 of them. 2 for the tank, and one for misc firewall sealant etc. Have used the small ones. Set up too fast for a bigger job. Great for taking front plate off etc. Hope this helps. Others may feel much different. I have done about 4 - 5 tanks ( mine and others ).
John Bender
Flying RV-12 - Serial #120036
Paid in May ( 5-2020 )
09-22-2015, 03:05 PM
The MC-236-B1/2 (if it is really B1/2) is also a 30 minute work time (the 1/2 means half of an hour).
Sealant labeled B2 is 2 hour work time. I will look into this, the B1/2 might be a typo.
Follow-up - If you order the MC-236-B1/2 you will get a a 2 hr cure sealant. The product was changed at some time in the past, and for reasons I will probably never understand, the part # was left as is from the original. If you order based on the product description, you will get what you want.
A tube of B1/2 sealant might be a challenge for a beginner to avoid having it start to harden up. The last thing you want is to rush for the sake of the sealant and end up with a leak.
As mentioned already, you by small scales real cheap that are more than accurate enough.
Scott McDaniels
Hubbard, Oregon
Reason: Correction
09-22-2015, 05:55 PM
Get the quart size and a cheap HF scale. This is really not a big/expensive/complex deal. It's nice not having worry about having sufficient sealant to complete the various sealing jobs. Besides, you will find many useful purposes around the house and shop for the leftover sealant!
David Heal - Windsor, CA (near Santa Rosa)
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 940+ hours (as of September 2020)!
V AF donation through June 2021.
09-22-2015, 06:35 PM
I do not think that fuel tank sealant should be used to seal the firewall. I set on fire some cured sealant with a propane torch. After taking the flame away, the sealant continued to burn. The smoke is not something that you would want in the cockpit. Is there something better to seal the firewall with?
Joe Gores
RV-12 Flying
09-22-2015, 06:59 PM
fuel tank sealant
FYI its easer to work on the fuel tank in several steps and time also the sealant is used on the wing tips.
09-22-2015, 08:30 PM
I suggest that a read of the excellent posts here is a good starting point for selecting a firewall sealant:
http://www.vansairforce.com/communit...778#post549778
09-22-2015, 09:11 PM
John,
Add my vote for the Quart Kit and a cheap digital mail scale that measures in ounces and grams. You'll use the proseal in a number of places, it is good for a loooong time if you store it cool, AND it's real handy for other things e.g. shoe repair (just sayin'). And it's so sticky and strong you can impress your friends by suspending an elephant that is glued to a chain with an single drop of the stuff! Kidding! I'm Kidding! Pretty sure it's never been tried. Hmmm...well we are experimenters...
Dave
RV12 N951DZ
First Flight 9/23/16!
No paint yet. Working on a scheme with John Deere colors or accents.
09-23-2015, 07:38 PM
Thanks for the input guys ?. guess an inexpensive gram scale is on the horizon.
I was just trying to avoid purchasing a gram scale because pre-measured is seemingly easier. Plus, I can just hear it now ? ?Did you hear about that guy with the pony tail down at hangar 45? ? Airport security found him with a gram scale and two large bags of white powder?. Honest officer, it?s only micro balloons and flox.
John
www.dogaviation.com
Now Flying!!
