Old 09-22-2015, 11:10 AM
Phantom30's Avatar
Phantom30 Phantom30 is offline
Default Easy Start Wires.....help
I am working on wiring the "easy start wires" page 46-13 steps 1 & 2. I screwed up and ran the little purple wire above the engine mounts instead of following the pito tubing. I'm trying to remove the little pins from the purple wire that enter the ignition module A1 and B2.
Does anyone know how and what bloody tool is necessary. I've already pulled one wire out, disconnecting it from it's pin and can't get the pin out.
Edit: they are the female connector pins which go into the bottom portion of the A2 and B2 plugs.
I'll be a happy camper when this wiring job is completed.
Ric Dickison
307 (CAB) Phantom
Search and Destroy (Can
Tho RVN)
Distinguished Flying Cross Society Member
CH-47 & UH-1H "Driver"
Rotax 9 Series Service IRMT
RV-12 Kit#729 "N312RD" is now a full functioning fun machine!! Thanks Van for fulfilling my dream😎
2018 Dues Paid
Old 09-22-2015, 06:56 PM
Sink Sink is offline
Banned
Look into the open end of the plug. You can see the metal pins and a small plastic tab above or below each pin. Take something pointy like a watch screwdriver or a dental pick and lift the plastic tab up as you put some backward pressure on the wire. It will come out easily.
Old 09-22-2015, 07:51 PM
Phantom30's Avatar
Thanks Sink.....they are out. Now to get a replacement pin from Stein.
Ric Dickison
307 (CAB) Phantom
Tho RVN)
2018 Dues Paid
