Old 09-21-2015, 08:36 PM
lsissom's Avatar
lsissom lsissom is offline
Default Mixture cable to engine brackets
Does this look right to you ? (assuming the pictures loads)
Seems like there should be some kind of retention feature here
[IMG][/IMG]
Larry Sissom - RV7A (N730RV)
wires and electrical stuff everywhere ...
Chelsea, Michigan
Old 09-21-2015, 09:06 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Nope - definitely not right!
The bracket on the engine requires a cable end that is threaded, and has two nuts that go on either side of the bracket. your cable is designed to have a retention strap that bolts to a horizontal plane and grabs the cable in the groove. You'll either need new cables, or you need to do some adaptation of the engine-mounted bracket to use those cables.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 09-21-2015, 11:42 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
What does the other end of the cable look like???
You may have a cable used for a quadrant, but installed backward.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 09-22-2015, 08:00 AM
DanH's Avatar
DanH DanH is offline
http://www.aircraftspruce.com/catalo...trolmounts.php
I prefer the fork type, on the right, for this kind of cable, but don't like the cheesy rivet in the Spruce part. Don't know the material choice either. For a critical cable, I make a fork from 4130 sheet the same thickness as the slot is wide, and add a bar retainer with positive fasteners. An add-on for your existing bracket could be like the lower example. Craftsmanship counts; all edges smooth, break all corners, observe proper bend radius.
Dan Horton
RV-8 SS
Barrett IO-390
Old 09-22-2015, 04:03 PM
lsissom's Avatar
Yes , I indeed DO have a quadrant .... and I may have in there backwards .
But i didnt realize it would affect the engine brackets . Thanks for the headsup
Chelsea, Michigan
