Old 09-21-2015, 02:42 PM
AviatorJ AviatorJ is offline
Default Complete part storage
If all goes as planned tonight then I will finish my VS. Two questions; it has some light scratches and finger prints all over it. The construction manual suggests running some 600 grit wet sandpaper over it to get the scratches out, which I assume would clean it off a bit. Is this the suggested method or should I use a damp cloth to wipe it off... leave the scratches since in about 5 years when I'm done it will get blasted and painted anyhow?
For storage I was going to wrap it in some paper to protect it and put it on the shelve... concern if it gets moisture on the paper it might promote corrosion... best to just put it on a shelve as is and try my best not to hit it with anything?
Thanks!
Justin
RV-10, N10JW
First Flight 2/14/2019
http://operationrv10.blogspot.com/
Old 09-21-2015, 02:48 PM
wirejock's Avatar
wirejock wirejock is offline
Default Congratulations
Congratulations.
I would leave it as in no sanding. Maybe wipe off the fingerprints (oils) with a solvent and put it in a safe place. I hung my parts from the ceiling. YMMV
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 09-21-2015, 03:11 PM
Easy enough, thanks.
Justin
RV-10, N10JW
Old 09-21-2015, 03:32 PM
I left most of the blue film on and wrapped the parts in bubble wrap before storing them in the garage rafters.
I can get away with leaving the blue film on because Boulder has a relatively arid climate.
Dave
Old 09-21-2015, 03:49 PM
BillL BillL is offline
Default Hung mine too . . .
Originally Posted by wirejock View Post
Congratulations.
I tried sitting them around and it always seemed to be wanting to be bumped with something else, so I hung them so they could easily be taken down. I can not claim some super logical argument in favor but it has seemed to work, Up, out of the way and no way to be knocked off. Also, easier than building more shelving. (cheap, lazy me)
Bill
RV-7
Lord Kelvin:
Old 09-21-2015, 09:33 PM
Far North Texan Far North Texan is offline
Wipe off the fingerprints with some acetone if you like.
Hanging the parts is the safest. Much less likely for them to get damaged that way.
RV-6A slow build,
serial # 21681. First flight March 1993
Dec 2019 donation paid
Old 09-22-2015, 06:46 AM
60av8tor 60av8tor is offline
Default An alternative exists
For those with an EXTREMELY understanding spouse
Jon
