I got the engine on the mount this weekend. The mount is on a car engine stand. Getting those lord mounts on is a bear, but we finally figured out you have to put the rubber on a bit crooked on the 2nd side, and it gets pulled into alignment as you tighten the bolt. We had to put a couple of washers in in some cases to make sure we didn't shank the bolt, but it all worked. Now I can start sticking stuff on the engine, which is a very pleasant break from riveting. And I can move the engine around the shop with ease. BTW the VANS baffle kit is a great value and fits well. It would take me months to make that by hand.
Scott Black
VAF dues 2020
Instagram @sblack2154
