Go Back   VAF Forums > Avionics / Interiors / Fiberglass > ADS-B
  #61
Old 10-14-2015, 09:17 AM
Originally Posted by Walt View Post
Just for the record, Freeflight's FDL-978-Lite UAT ($1995) is not "experimental", it is a fully certified TSO'd unit eligible for installation in certified or experimental aircraft. L-3 also offers a certified UAT for just $1799! Both have built in GPS.
Walt, would my European approved Becker 150 watt mode S transponder work with either of these systems for now or would I get a letter from the FAA to cease and desist?
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 10-14-2015, 09:40 AM
Walt's Avatar
Walt Walt is offline
Two issues here, the Becker will not digitally control either unit (a work around is possible here) but more importantly is the issue noted below, I'd have to look into this further to give you an answer.
"UAT systems with Mode S transponders. Do not install a UAT ADS-B OUT system which has the capability to transmit a random 24-bit address in an aircraft which also has a Mode S transponder unless the random 24-bit feature is disabled. The ATC automation system would interpret the different 24-bit addresses as two separate aircraft, and alert controllers to a conflict that does not actually exist."
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 10-14-2015, 11:23 AM
Jerry Kinman Jerry Kinman is offline
Default Interesting Thread
I will be contemplating my options in the next 4 years as the avionics industry continues to develop affordable solutions for my RV8. I also have a newly restored 1941 Taylorcraft BC12-65 that will take me anywhere I need to go with the dollar investment roughly equal to a full glass modern ADS-B compliant RV panel.
After retiring from two flying careers, both military and civil, I am content to move back into the slow lane and let the big spenders pass by.
RV-8 N88GK Sold
RV-9A Slider, N188GK Project, now flying, O-320-B1A, Catto 3 Blade NLE, G3X Touch System
Restored Taylorcraft BC12-65
Exempt but proud contributor
Jerry Kinman, VAF 170
Keller, TX (T67)
Old 10-15-2015, 08:03 AM
pierre smith's Avatar
Default Say, Walt.
I have a 430W in my -10. and a certified GTX 327 encoded transponder.
How cheap can I get by with only ADSB out? I'll use my eyes for the 'In' part.
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 10-15-2015, 12:19 PM
Pierre,
I have the same equipment. I think the least expensive solution is to sell the 327; replace it with a Trig mode SES (22 or 31); get a software upgrade on the 430W so it puts out ADSB+. If you want ADSBin there are lots of $500 boxes, depends on what you have in your panel for a display. I'm lucky that GRT supports a remote TT22 for $2200, minus what I get for the 327; plus lots of 'in' choices. The Navworx EXP system is pretty similar in cost, remembering that it needs you to add antennas.
As you say 'in' is optional, but it doesn't add much to the cost. And NexRad is, inho, worth the cost. I dropped xm wx so the 'in' box, in my mind, is 'free'!
