09-15-2015, 06:31 PM
Butterfly valve 4 oil cooler,Who sells it? ?
My friend has a Vans oil cooler mounted on the firewall with this neat after market 2 3/4" butterfly valve with a 3" hose from the back side of the rear baffle wall. It's the butterfly valve that's needed. Anybody know of the vendor who sells them for RVs.
Ron in Oregon
09-15-2015, 06:40 PM
Are you talking about the oil shutter or a shut off valve for tubing?
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
09-15-2015, 07:16 PM
Bill
RV-7
Lord Kelvin:
09-15-2015, 08:40 PM
Well considering I wasn't clear I apologize to the first Bill and say to the second Bill,,,,yep that's the one the guys are talking about as being very efficient. Are there any others who like it ,,,that this butterfly air valve is a good thing?
Thanks Bills much appreciated.
Ron in Oregon
09-16-2015, 02:14 AM
Mothership!
Vans, accessory catalog:
Description
Shutter designed to mount between the baffle and oil cooler to allow airflow regulation when the engine oil temperature is too cold.
Will fit the EA OIL COOLER II. Weighs 6oz.
Requires a cable to operate from the cabin if desired
(CT A-740 and HW WIRE NUT KIT - not included).
Ordering Information
Cooler Shutter
Part Number = EA OIL COOLER VENT
Price = $85.00
Dominik
RV-7A, TMX-IO-320, FM-150, Sensenich FP
Flying since 28. April 2016
09-17-2015, 10:20 AM
Thanks Bill, got that butterfly valve orded from Avery tools, Thanks
Ron in Oregon
09-17-2015, 11:14 AM
Napa Auto parts has a Beldin type push-pull cable that you turn the knob to friction lock.
Works great with this valve.
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
09-17-2015, 04:02 PM
I firewall mounted my oil cooler and added the butterfly valve from Avery in the SCAT ducting between the baffle and cooler. I then ran a Bowden cable to the cockpit for control of the valve. It works Extremely well with out setup. Helps to warm the oil faster on the ground and precisely control oil temp in the air. It took a lot of labor to get everything to fit right and correct oil hose lengths, Bowden cable routing, etc., but was absolutely worth it.
________
Trevor Conroy CFII, MEI
Airbus Pilot
N781TD
RV-7
First Flight - April 12, 2015
Construction Log
