Old 11-26-2006, 07:28 PM
ronoc74 ronoc74 is offline
Default AFP throttle and mixture lengths
I posted this in the injection systems section but it seems it went unnoticed. A few people must have used this config already.
I'm about to order the finishing and fwf kits but Van's are unsure what cable lengths are needed for AFP injection on an IO-320 with vertical induction. The cable lengths for a 7 with O-360 are the same as a 9 with O-320, so I assume what works on a 7 with AFP & vertical will work on my 9.
Conor McCarthy
RV-9A 90990 flying
QLD, Australia
Old 11-28-2006, 12:33 PM
kentb's Avatar
kentb kentb is offline
Default Not sure if my setup is the same or not....
I have a 9A with IO 320 CS prop. My vertical throutle body has the mixture on the left side, not the back. Is that what you are talking about?
If it is there are some adjustments that you will need to do. I did the following:
1. Order a new TB control arm for the mixture (like the one on the right with a one inch offset, S shaped).
2. Order a longer mixture control cable (I think that it might have been 52 inches, but would need to look it up. Vans doesn't carry this. Ordered it from Spruce).
3. Created a bubble in the left side of the cowl so that the TB mixture arm didn't hit the cowl on startup and shutdown.
If this sounds like the info you are looking for, let me know and I can round up more information and pictures.
Kent
Kent Byerley
RV9A N94KJ - IO320, CS, tipup
AFS 3500, TT AP, FLYING....
Canby, Or
Old 11-29-2006, 06:51 AM
Thanks for your reply Kent. If your engine has the usual Bendix injection then I think your setup is different to what I need for the Airflow Performance system.
Conor McCarthy
RV-9A 90990 flying
QLD, Australia
Old 11-29-2006, 09:01 AM
frankh's Avatar
frankh frankh is offline
Default Its hard to tell
Unless someone has exactly the same setup as you. I have AFP on a FF sump and the standard length mixture cable worked but I had to extend it with some 3/16th "Allthread" , coupling nut and lock nuts.
I had to do the same with the throttle but then I have a left hand throttle as well.
I would just get the same cables and make sure you keep them in a safe place in case you have to return them.
Frank
