Go Back   VAF Forums > RV Firewall Forward Section > Electronic Ignition Systems
Old 09-15-2015, 10:48 AM
thinkn9a thinkn9a is offline
Question Dual pmag hot start settings with fuel injection
Looking for recommendations on sequence and settings for hot start, with dual pmags and fuel injection.
With just a couple tries so far, i have failed to come up with the magic combination.
My starter and battery thank you.
Wallace & Marietta Goodloe
9A -QB
N211LV
Phase 2 has started!
Thanksgiving time, is dues time for us
Old 09-15-2015, 11:00 AM
N941WR's Avatar
N941WR N941WR is offline
What engine do you have, compression ratio, sparkplug & gap, what timing are you running, and what fimware version is on the P-mags? If your P-mags are installed properly, they should help with hot starts.
Finally, what starting technique are you using?
Check you PM's.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 09-15-2015, 11:20 AM
Bevan Bevan is offline
Also, procedure makes a difference should you have a purge valve or not.
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 09-15-2015, 11:25 AM
miyu1975's Avatar
miyu1975 miyu1975 is offline
My technique
Feet on brakes
Half throttle
Mixture full off
No priming
Fuel pump off
Start cranking and slowly add mixture once she starts to fire up.
Adjust throttle as needed
Worked every time.
Ryan Allen, CFII
RV7 N612RA, flying since july 2012
E-170/175
RV10 Tail Kit complete, Wings 90%, fuse on order
Acro Sport 2, building
Old 09-15-2015, 12:10 PM
tommylewis's Avatar
tommylewis tommylewis is offline
Default Same here
my technique for a hot start is same as Ryan only I set the throttle to about position that gets me about 1200 rpm, works every time
Tom Lewis
RV7a N967BT 1900 hrs.
RV10 N143EB 960 hrs.
Granbury, Tx
http://bit.ly/2bnimsZ
Old 09-15-2015, 01:29 PM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
This is how I do it FWIW.
Throttle open 1"
Mixture full rich
Fuel pump on until you hear a distinct change in pump noise
Leave fuel pump on
No prime
Start as normal
When engine catches then throttle to idle (1000rpm)
Works for me every time
This is shown at: https://m.youtube.com/watch?v=7n_zwFfsQjs
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2020 Donation made
www.PuertoRicoFlyer.com
Old 09-15-2015, 02:13 PM
maniago's Avatar
maniago maniago is offline
As I remember from the Lycoming class, the issue is that the injectors bleed down into the intake manifold over time - like 20mins or so. So regardless of anything else, you have a rich puddle of fuel that you are trying to ingest. So what you don't want or need is more fuel. What you do need is enough air to whip up the puddles and give you something ignitable and of course a thumping good spark to blow though it. Pretty assured your pmags fit that bill.
Again from memory, its mixture off, no prime, crack the throttle, twist until it lights then mix full and throttle to desired. You don't have to slam them home to keep it running. There's usually enough fuel lying around to keep it lit for a good 2 or 3 secs of 1000rpm, which is plenty of time really.
This is what we do in the Citabria and it works as advertised.
Mani
Busby MustangII (FoldingWing) Pending DAR.
Don't be a hater; I'm a cousin with thin wings!
N251Y (res)
Old 09-15-2015, 03:23 PM
Originally Posted by maniago View Post
As I remember from the Lycoming class, the issue is that the injectors bleed down into the intake manifold over time - like 20mins or so. So regardless of anything else, you have a rich puddle of fuel that you are trying to ingest.....
Which is why the purge valve in AFP's injection system makes good sense. When the engine is shut down there is no fuel in the flow divider to the injectors to bleed down.
Hot start (for me) is run fuel pump about a minute to circulate relatively cool fuel through the system, set the throttle about a quarter inch, hit the starter and go purge valve knob in and the engine starts right off.
It works for me because it is so simple, I have trouble with systems without the purge valve.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 09-15-2015, 03:32 PM
maniago's Avatar
I assume that a purge valve means that it just bleeds off the fuel pressure in the divider and lines, right? I assume that the AFP system has a fuel return line then - which the factory Lyc does not.
Mani
N251Y (res)
Old 09-15-2015, 03:38 PM
Yes, The purge valve needs somewhere to dump the pressure to. Fuel tank is best so you can also circulate fuel back to the tank prior to engine start.
Bevan
Dual P-mags
Grand Rapids EFIS
