Old 09-11-2015, 08:35 AM
YellowJacket RV9 YellowJacket RV9 is offline
Default Oil Door Orientation
Can anybody think of a reason why the oil door can't be oriented with the hinge on the forward edge? I misread the plans when I did the cutout; would be easy enough to fix if needed, just some fiberglass work, but then I wondered, why not just install it this way?
Chris
Chris Johnson
RV-9A - Done(ish) 4/5/16! Flying 4/7/16
Old 09-11-2015, 08:41 AM
rmartingt's Avatar
I guess if you use something other than a piano hinge, it should work.
Only possible downside I could see is if it's not closed and latched you might not notice as easily... but then, it might also not be as likely to depart the airframe, either?
RV-7ER - finishing kit and systems installation
Old 09-11-2015, 08:53 AM
Hmm I forgot about the curve affecting the hinge. Think I will probably just re-do.
Chris
Chris Johnson
