Old 11-26-2006, 12:52 PM
BillyBob BillyBob is offline
Default Empennage History
To help me understand the several rudder,VS,HS types, I have a question.
I have heard that late RV-6 kits (2001) had the larger RV-7 VS and rudder Counter balanced). Also other posts have indicated that there were 2 rudders used on the RV-7/8??
Can anyone summarize the timeline of the various HS/VS/Rudders used on the RV-3,4,6,7,8,9 models? I assume the 10,12 models are totally unique and possibly the 9 HS is also.
Bill
Flying RV-6A
Thinking about RV-?
Old 11-26-2006, 01:27 PM
Mel's Avatar
Mel Mel is offline
I can give you the order but not dates. The original -3, -4, -6 had non-counter-balanced rudders. Later on the -6 got the -8 counter-balanced rudder as did the original -7. Next change was to change to the -9 rudder on the -7 for better spin recovery. The -10 is a totally different animal.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 11-26-2006, 02:34 PM
Thanks, Mel.
That matches most everything I have been reading. My interest is that I have been looking for an orphaned kit to finish building. One recent RV-6 QB kit (2001) I looked at appeared to have the -7 empennage or VS/Rudder at least. Now it appears it might be an advantage to try for a late -7 as opposed to an early one? I assume the changes were all to make improvements in handling.
bc
Bill
Flying RV-6A
Thinking about RV-?
Old 11-26-2006, 02:52 PM
rvbuilder2002's Avatar
bc
Actually, the RV-6 only changed to the RV-8 rudder to gain some parts commonality and reduce inventory.
The RV-7 changed to the RV-9 rudder for a slight improvement in spin recovery (it wasn't bad as it was, but it wasn't quite as good as the RV-6, as Van had orig. said). So the different rudder was offered to builders and then standardized into the kits shipped after that tiome.
Scott McDaniels
Hubbard, Oregon
Old 11-27-2006, 06:08 AM
pierre smith's Avatar
Default -6
Hi Bill,
IMHO, you can get a better bang for your buck with a -6. Since it has been discontinued and replaced by the -7, the prices seem to reflect that as well. Furthermore, I don't see much speed difference either, having flown both.
Yes, find an orphaned 6 and save money
Regards,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
