Old 11-26-2006, 01:20 AM
AntiGravity's Avatar
AntiGravity AntiGravity is offline
Default #4 CSK ST-ST tinnerman washers
Just to let the group know, I too have scoured the Internet unsuccessfully for this type of washer. So I found these guys and thought I'd pop the question. I haven't had a reply yet (only just sent it), but when I do I'll post back here.
Hi,
Ref:
http://mrwasherman.com/index.html
Many builders of RV series of aircraft attach the fibreglass wingtips to the wing using #4 countersunk screws rather than the specified pop rivets. However, this causes problems with the paint finish if the tips later have to be removed. Many builders have searched the Internet, unsuccessfully for #4 100 degree countersunk stainless steel tinnerman-type washers for this application.
Do you make such a washer? If so, how much are they and in what quantities.
If not, can you make such a washer? Again, how much would they be and what minimum order would be required?
If you are able to assist I shall post a message in the VansAircraft Forums with your information so that builders know where they can get these washers. As for myself and another local builder here in NZ, we'd need two hundred or so of them (100 each). Let me know.
Jeff Preou
Hamilton, New Zealand
Jeff Preou
STATUS: not building anything at all... yet ...
http://www.preou.com
http://www.kitlog.com/users/index.php?user=jpreou
Old 11-27-2006, 01:23 AM
RudiGreyling's Avatar
RudiGreyling RudiGreyling is offline
Thanks Jeff,
Looking forward to their reply...
Regards
Rudi
Rudi Greyling, South Africa, RV 'ZULU 7' Flying & RV 'ZULU 10' Flying
"Science, freedom, beauty, adventure...what more could you ask of life? Aviation offers it all" - Charles A. Lindbergh
Old 11-27-2006, 06:02 AM
yakdriver yakdriver is offline
Why not use your dimpler and make your own? Don
RV 7 N212MD Flying as of 12/22/2007
Backcountry/TCOW Super Cub flying 03/12/2011
Next project?
Old 11-27-2006, 11:09 AM
Default ST-ST disks!
I thought of that too, but wasn't able to find ST-ST blanks. Also, the csk formed by the dimpler seems to be more rounded than the tinnermans I have seen so far and I wasn't sure how flat the home-made washer would sit. If I could get some suitable ST-ST washers that had a #4 hole and a decent OD then I'd try it...
Jeff Preou
Old 11-28-2006, 06:15 AM
sjhurlbut sjhurlbut is offline
You're right. The home made ones using a dimpler don't turn out as nice. The dimpler makes them more 'V' shaped whereas the purchased tinnermans have the sides bend parallel. I made about 2 dozens for some fiberglass cover panels and would buy some new #4 if they were located.
Steve
RV7A
Old 12-06-2006, 05:01 PM
Post Reply from Mr.Washerman!
Here's the quote that I received (summarized) and my subsequent reply.
Hi there Hector,
thanks for the quote: I shall pitch it to the VansAirforce guys and see what they think.
Please excuse my ignorance, but just so I get this straight for the guys, please confirm:-
If we order 100 washers then the cost is $332
If we order 1000 washers then the cost is $32 (10x $3.20 per 100)
Or do I read it wrongly? Because that seems to be a huge disparity!
Are perhaps the numbers for packs of 100 washers? (as in, 1000 packs of 100 washers?)
Sent: Thursday, 7 December 2006 9:26 a.m.
To: Jeff Preou
Subject: RE: MrWasherman - #4 CSK ST-ST washers
Quote # 5551
12/06/06
Part Name
N/A
Part / DWG No.
Material Required
Stainless Steel
Qty 100 1,000 5,000
Per 100 pcs $332.00 $3.20 $7.20
Delivery
4 Weeks to ship
NOTES: 100 pc would be insignificant for you and for us PLEASE see price break(s) above.
Price Quote Disclaimer:
Prices: are good for 2 Weeks from the day of the quote (UNLESS OTHERWISE SPECIFIED)
Jeff Preou
Old 12-06-2006, 06:26 PM
Post Clarification
Here's the reply.
Correct pricing for ( 1,000 Pcs @ $33.20 per 100) = $332.00
Same total cost for 100 Pcs a guess in other words Minimum buy is 1,000 Pcs
So we need to front up for at least 1000 washers. I need 100, and another local guy will probably need 100. That's the number of nutplates/screws in the Cleaveland #4 wingtip kit, by the way. So to make this purchase we'd need another eight guys for a similar amount.
Now, I could do the group buy thing, but since I am in New Zealand it really wouldn't be effective for me to do so. Any takers? The other option would be to purchase and onsell at cost + freight )in my case, a portion of the freight here as well as the actual freight back out again, which wouldn't be very cost effective).
Whaddaya think guys? Or perhaps we should petition someone like Cleaveland or Aircraft Spruce and see if they want to front it all for a guaranteed number of buyers (though they would more than likely add a significant cut for doing so?).
Comments?
Jeff Preou
Old 12-06-2006, 09:18 PM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default Tinnermans
I am not sure why you want to go with these. You'll find they are a PITA. I used them initially then replaced them with 6-32's. Much happier now.
I purchased a bunch of them but can't remember where. They were no where near that cost. The price you are getting is ridiculous and for that reason alone would go with 6-32's.
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
Old 12-06-2006, 10:28 PM
I am interested...but like you I am in South Africa
I have also already bought the cleaveland wing tip set, so I am kind a of locked into the #4. Is the #4 really such a pain? I'm sure there are many builders out there that it works fine, why else is cleaveland selling those kits?
If we get 8 more people together someone in the USA can do the subdivide and forward it to the rest of us. Defnitiley do a groupbuy thing, I am sure some USA builder will jump in and assist, since the RV community is all about helping each other.
The other option, if we do not get 8 more people is to Send an Email to Cleaveland, ask them to stock it, and sell it as an add-on to their wing tip kit.
Regards
Rudi
Old 12-07-2006, 12:35 AM
Default Cleaveland kit
Like Rudi, myself and the other local builder I mention are also already locked in to the #4 kit from Cleaveland. That's three of us, and I'm sure there must be more. I suspect th 6-32 are better, and overall would likely be cheaper, but since I already have the #4's that's what I'll be using. Next time, when I'm maybe a little wiser, perhaps I'll go to the larger size. Unless someone out there wants to purchase a Cleaveland #4 stainless wing tip kit? :-)
Otherwise, come on guys, lets see if we can't get this sorted...
Jeff Preou
