Old 09-04-2015, 10:51 AM
Gizmos Gizmos is offline
Default Start and termination of CAN
I am using gsu 73,2)g3x ,a/p305 and roll and pitch servos GSA 28. Do I want to run the CAN 22 gauge shielded two wire from gsu73 to end at GSA 28 pitch servo. Each connection (node) to CAN will be less than 12 in. Is this the. Or react way to route the CAN wires? When you tie into the CAN, do you just remove the shielding, solder the nodes to the CAN and then put a jumper wire across the shielding to keep continues. Sorry for so many questions, I have read the 700 pages to much.
Old 09-04-2015, 10:53 AM
Default Jumper wire for shielding
Can I use the same wire 22 gauge for the jumper on the shielding or do I need to use braided wire?
Old 09-04-2015, 11:08 AM
Pat Hatch's Avatar
Pat Hatch Pat Hatch is offline
Check out this thread, it may contain the answers you are looking for.
http://www.vansairforce.com/communit...light=wire+bus
To your second question: you can use non-shielded wire for the carry-through of the shields, AWG22 is fine. Look for the green wires in the photos in the attached thread.
Pat Hatch
RV-4 (Gone to RV heaven)
RV-6 (N44PH - Flying)
RV-7 (Sold)
RV-8 (Builder & Avionics Installer)
www.phaviation.com Trim Relay Boards/Flap Actuators
www.pathatch.com/blog (Photography)
Track Me
Old 09-04-2015, 11:31 AM
flyboy1963's Avatar
Default OMG!! don't DO that!!!
I didn't get the memo......Canada is being......TERMINATED?????
( robots from the future?....or just being bought by Jimmy Buffet for $100? )
...just a nervous CAN resident!
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 09-04-2015, 06:23 PM
vluvelin vluvelin is offline
Default CAN
Wire must be twisted pair. Shilding is preferable.you can connect shildin any way you want.
All nods must be connected in paralel
Depending on type of CAN you may need load resistor if load is not provided by any of the nodes this info probably will be in installation manual
RV7 C-GLLT - FLYING
RV7 C-GZZY- NOTFLYING
2017 June RV7 Emp in works!
VAF SUPPORTER
2014, 2015, 2016, 2017, 2018
