Old 11-25-2006, 03:50 PM
scard's Avatar
scard scard is offline
Default Where to safety tach cap?
Any good ideas on where to safety wire the tach cap to? How about drill a small hole through the end of that case stud for the aux alternator and safety wire to that?
Scott Card
CMW E-Lift
Old 11-25-2006, 04:41 PM
Mel's Avatar
Mel Mel is offline
That'll work, but why not just double nut the stud and safety wire between nuts? BTW, the cover on the tach shaft is only a dust cover. There's an oil seal inside.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 11-25-2006, 06:29 PM
dan's Avatar
dan dan is offline
Or wrap it around the breather fitting. Simpler = better.
Dan Checkoway RV-7
Old 11-25-2006, 07:56 PM
az_gila's Avatar
az_gila az_gila is offline
Smile What wire?
Interestingly enough, the certified, STC'd, high price cover that came with the Horizon digital tachometer for the Tiger didn't come with any safety wire holes....
Scott, which supplier provided the one in the picture?
And they claim "certified" is better.....
gil in Tucson
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 11-25-2006, 08:48 PM
scard's Avatar
The tach cap that I have is an Andair cap from ACS.
Scott Card
CMW E-Lift
Old 11-25-2006, 09:02 PM
Ironflight's Avatar
VAF Moderator / Line Boy
gil in Tucson
And the one that I got for the RV (I honestly don't rememebr where), has a central piece with a hole for the safety wire, and then an outer ring that actually screws on to the threads. In other words, the part that "fastens" doesn't have a saefty wire hole, and the part that doesn't...does! I didn't even bother with a safety, cause it wouldn't hold anything...
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 11-25-2006, 09:14 PM
walter's Avatar
walter walter is offline
I tried two caps. None fit. There wasn't enough room to even screw it on.
Then I was told it's not needed. Hasn't leaked yet.
Walter Tondu
Flying RV-8A - Fastback, IO-390, G3X Touch, 74 HRT
Prior RV-7A Build Log
Old 11-26-2006, 07:06 AM
Mel's Avatar
Mel Mel is offline
As I said before, it's primarily a dust cover. It keeps dirt from getting into the seal.
Old 11-26-2006, 07:50 AM
AlexPeterson's Avatar
I'll safety wire mine as soon as I find it. I lost is somewhere over the United States, so it might take a while. That was 700 hours ago.
I had to machine it on the lathe just to get it to fit, and it is only a dust cover, so I never bothered to replace it.
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
Old 11-26-2006, 08:41 AM
scard's Avatar
This is all very entertaining. I really had no idea there wasn't any oil pressure in there, but it sure makes sense. So I guess the idea is not to worry so much about really safety wiring it, but maybe at least tether it to something so it is at least there to put back on . I appreciate the comments.
Scott Card
CMW E-Lift
