Old 09-03-2015, 06:47 AM
Kubi Kubi is offline
Default Advice needed: Rust inside Lycoming Cylinder
Godday
I have a low time (less than 100hrs) O-320, nitride hardened Cylinder which shows some pits and patches of rust.
I cleaned/decarbonized the head inside but did not touch the cylinder liner yet.
What do the engine experts recommend to do?
https://picasaweb.google.com/Pilotqb...69023243539858
https://picasaweb.google.com/Pilotqb...69025356260226
https://picasaweb.google.com/Pilotqb...69026029122610
https://picasaweb.google.com/Pilotqb...69024608195554
Old 09-03-2015, 07:12 AM
Mike H Mike H is offline
Since this is a very low time engine, and you already have it apart, you may want to hone the cylinders and install new rings.
I have had good sucess in the past with removing fairly minor rust from cylinders with scotchbrite by hand, then cleaning thoroughly and reinstalling the existing piston and rings. Some minor pitting will not affect the cylinder, especially if it is smoothed out with some scotchbrite.
Mike Hammond
A&P IA PPL ASEL
RV-14A kit S/N 140170
Old 09-03-2015, 03:47 PM
Thank you Mike!
Appreciated.
I would love to see a couple of more answers from others.
Come on.
