Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
Old 09-01-2015, 06:18 AM
rwayne rwayne is offline
Default 430W to 650
I'm thinking of upgrading my 430W to a 650. I understand the plugs have to be re-pinned. Does the 650 use the same pin type as the 430 or will I have to cut the old pins off and replace with new ones for the 650 plugs?
Old 09-01-2015, 06:40 AM
rleffler's Avatar
rleffler rleffler is offline
To be honest, I don't remember what pins are used on the 430. I believe that all the pins on the 650 are the high density type or at least the pins I used.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 09-01-2015, 07:20 AM
Raymo's Avatar
Raymo Raymo is offline
The 430 has one high density connector and two standard density connectors. I don't know what the 650 has.
No need to "cut" the connectors off the 430. Just de-pin (after labeling) and re-pin for the 650 as needed.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 09-01-2015, 09:11 AM
N941WR's Avatar
N941WR N941WR is offline
Garmin did not make the upgrade a plug and play job. However, Avidyne did make their's compatible with the Garmin trays and plugs.
http://www.avidyne.com/products/Ifd540/
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 09-01-2015, 02:18 PM
Bill Boyd's Avatar
Bill Boyd Bill Boyd is offline
You can find HOP-ALONG without one of those fancy IFR navigators. Just do it.
Old 09-01-2015, 04:48 PM
Jesse's Avatar
Jesse Jesse is offline
Actually, the 430 has 2 high density connectors with pins (male) in the back shell with an optional third of the same kind, then one standard density female connector. I'm not sure what goes in the female connector, but I'm pretty sure it's the audio connector.
Jesse Saint
