Old 08-29-2015, 08:32 PM
wmhutson wmhutson is offline
Default Roll servo in wing tip
Installing roll servo in wing tip need info on size and place to purchase push/pull tube
Old 08-30-2015, 09:23 AM
Isaac's Avatar
Isaac Isaac is offline
Default RE: Roll Servo in Wingtip
Sam Buchanan's web site on how he installed a Navaid AP roll servo in the wing tip of his RV6 is a good example of how to accomplish this.
http://home.hiwaay.net/~sbuc/journal/navaid.html
I used Sam's installation as a guide on my RV6, but used the same components (tube dia etc.) that are used for the primary aileron controls. Here is a list of the parts that I ordered from Van's Aircraft.
AT6-035 X 1 1/8" X 6 Feet Push Pull Tube
VA-111 Female Rod End (W-416) (qty 2)
Bearing MD3614M 3/16 X 3/8 Rod End (qty 2)
AN316-6R Nut Thin Jam (qty 2)
Washer 5702-75-60 Steel Washer for AN3 (qty 2)
As far as the final length of the servo push tube, you will have to determine the correct length when you have everything in place. Hope this helps.
___________
James
RV6 N947J
