Hello everyone,
I currently have:
Aerosport IO-375 B1B engine. C/S, 195 hp, dual P Mags.
Cummins Polished Aluminum spinner
Considering these for purchase:
PCU 5000 Governor
Hartzell Aluminum C/S Prop Part Number = PROP C2YR-1BFP/F7497
- Anyone running this combination? Thoughts?
- Any issues with governor cable bracket?
- Still trying to decide between 74" or 72" prop. I don't see an obvious reason to go 74"
- Any other things I should consider?
I'm trying to complete the PCU-5000-x Spec Sheet (located at the bottom of this post:
http://www.vansairforce.com/communit...909#post899909
Any input for the information (right column, especially control lever angle and rotation) and diagram would be appreciated.
I've got calls placed to the respective companies for these parts as well.
Lots of learning!!! Thanks!
