Old 08-26-2015, 12:37 AM
ron sterba ron sterba is offline
Default Transponder,does it need to be registered w/ FAA
Just receivedmy completed registration for my ELT 406 in USA. Does my Dynon transponder need to be registered with the FAA??,,,,Does the transponder need have any airworthiness paper?, Also I have a official N number. Also if I travel to Canada to I need to register my ELT with the aye group! If I fly in Canada do. I need 12" aircraft numbers.
Ron in Oregon
Old 08-26-2015, 12:46 AM
Ron in Oregon
1. Registered, no. But all mode S transponders need to be programmed with their FAA mode S code (found on FAA web site).
2. Transponder must have and pass biennial (2 year) checks, documented in a/c maintenance records
3. Not sure, but I think your ELT is okay in Canada
4. Cross any foreign border, you need 12" N numbers. Tape is okay if done to spec.
Old 08-26-2015, 01:51 AM
Bevan Bevan is offline
Your foreign registered ELT will be just fine with your foreign registered aircraft. 12" ident not required/enforced for your northern border. You should register your aircraft with US customs and receive/apply their sticker to the aircraft before you leave the country.
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 08-26-2015, 06:24 AM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
Close, but not quite right. 12" numbers are only required if going through an ADIZ. There is no ADIZ along much of the US/Canada border.
See the relevant FAR.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 08-26-2015, 06:36 AM
MikeyDale's Avatar
Having recently completed this, to be legal entering controlled airspace, your transponder has to be certified and then re-certified every two years. I just had this done by Walt Aronow at EXP aircraft services in Roanoke, Tx. Not sure how you can get in trouble by not doing this other than having an incident with ATC and not producing proof that it has been done. Walt made an entry in my aircraft logbook.
Mike Hillger
RV 7 FLYING SINCE 4/2015!
Garden City, Texas
Dues Paid
Old 08-26-2015, 02:07 PM
I also believe NOAA asks you to register your ELT.
http://www.beaconregistration.noaa.gov/
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
Old 08-28-2015, 05:42 PM
Thanks Guy, Sorry late getting back on here. It was vacation time! I just received my confirmation yesterday from NOAA for the USA but now I am going to get the Canadian form filled out too! Transponder,,, well I'll put the feelers out on this one for a shop near by. Thanks guys much appreciated as always
Ron in Oregon
Old 08-28-2015, 07:04 PM
bruceh's Avatar
bruceh bruceh is offline
When you register your aircraft N-number, there is a unique Hexadecimal code assigned for your Mode-S transponder that you need to program into your unit. On the Skyview system, you just put this into a configuration menu.
Bruce Hill
2020 VAF donator
Old 08-28-2015, 08:13 PM
Infidel's Avatar
Infidel Infidel is offline
I'm thinking a radio operators license is required for a trip to Canada as well.
Old 08-28-2015, 10:21 PM
Strictly speaking a radio operators license for the pilot, and a radio station license for the airpane. $65 and $160, respectively, to the FCC. I have never heard of these being checked, but ymmv.
