Not finding much instruction for installing the manual trim... Do I drill the fuel valve/trim plate to allow the cable to go through tail end first or does the knob come off allowing you to insert only the knob end from the bottom side of the plate? If the former, I'm assumng that hole in the plate will have to be pretty big--1/2" or bigger--to allow the black threaded portion of the cable (see photo) to go through?
Thanks for any help and Happy Thanksgiving.
