The pickup/valve is very possibly internally clogged. If you were getting SOMETHING out, then you probably could have fixed it by just holding the can upside down and spraying for a bit...sometimes that works.
With nothing coming out, you're may be out of luck, unfortunately. It's super critical to hold the can upside down after every use (even if you're just going to put it down for 5 minutes to grab a beer) and spray until it's just propellant coming out. If you do this religiously, you'll get every last drop out.
If they're new cans, I'm baffled. With cans that have been used once or twice, though, this isn't uncommon if they're not cleaned REALLY well after use.
Good Luck!
