Old 08-21-2015, 11:24 AM
rph142's Avatar
rph142 rph142 is offline
Default Wanted: Oil Sump Strainer
I plan on removing my Christen inverted oil system in pursuit of a lighter weight fwf. In doing so I will have to convert the sump strainer back to stock. Lycoming and ACS want nearly $400 for this tiny screen! Does anyone out there have one lying around or know where I can find one? Perhaps you converted your stock setup to the Christen sytem and you have a leftover screen.
Rob
Rob Holmes
www.myrv3.com
N59LG
The minimum number of planes one should own is one. The correct number is n+1, where n is the number of planes currently owned. This equation may also be re-written as s-1, where s is the number of planes owned that would result in separation from your partner.
- Veluminati
Old 08-21-2015, 02:50 PM
krw5927 krw5927 is offline
I see you have an IO-320, so most likely you need Lycoming p/n 70484.
http://www.aircraft-specialties.com/...suction-70484/
Kurt W.
RV9A
FLYING!!!
Old 08-21-2015, 03:43 PM
rph142's Avatar
Wow thanks! I must have been looking at the platinum edition screens last night.
Rob Holmes
www.myrv3.com
N59LG
- Veluminati
