Old 08-12-2015, 11:43 AM
Ed_Wischmeyer's Avatar
Ed_Wischmeyer Ed_Wischmeyer is offline
Default Inexpensive audio panel recommendations?
My RV-9A has a FlightTech ITC-402P intercom, and there are problems. Audio quality is good in Isolate mode, but in the ALL mode, there's lots of noise.
No, I have not debugged all the wiring to the copilot side, but the symptoms may indicate an internal problem.
The existing radio is a GTN650, hooked directly to the intercomm with 150 ohm resistors on the comm and nav signals, and with the G3X alerts coming through another resistor (they're not working yet). I thought it would be real cool to use a GTR200 as the intercomm, hooking up the GTN650 through one unswitched audio input with a simple toggle switch for, granted, limited but adequate audio panel functionality. I'm still looking for somebody else who appreciates this brilliant idea but have decided instead to take the hint and abandon the idea.
I really don't want to spend a bunch of money for an audio panel with lotsa features I don't need or want. Anybody got any good suggestions? Or does anybody have an SL-15 looking for a really good home?
thanks
Ed
RV-9A at KSAV (Savannah, GA; dual G3X Touch with autopilot, GTN650, GTX330ES, GDL52 ADSB-In)
Previously RV-4, RV-8, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
2020 dues slightly overpaid
Retired - "They used to pay me to be good, now I'm good for nothing."
Old 08-12-2015, 12:01 PM
Mousse Mousse is offline
http://www.aircraftspruce.ca/catalog...audiomixer.php
I used the above in my -9 with good results.
Exempted but dues paid through 12/2020
RV-9 Sold
RV-10 Flying
Old 08-12-2015, 12:10 PM
flightlogic's Avatar
Van's sells a blind audio mixer. It only makes sense to use a mixer if you are sourcing with two com radios though.
They are not really designed to solve intercom issues.... unless you go with a high end unit like PS that has intercom built in.
"Kindness is never a bad plan."
exemption option waived. Donation appropriate.
Old 08-12-2015, 12:52 PM
If you have some free time you can do what I did: build your own intercom, with mixers on the front end for as many inputs as you want or need. The most expensive parts are the knobs. I use the radio's volume controls as listen/don't listen. A single switch moves the mic and PTT between coms. Passengers have their own volume controls for radio and music, so if they want music and you don't, just turn your music volume all the way down. If you don't want to hear the passengers turn your intercom volume down. If they don't eant to hear you, turn your squelch to off.
I can send you the schematic if you're interested. Nothing hard, but some small parts to soldered
Bob
Old 08-12-2015, 01:08 PM
vlittle's Avatar
vlittle vlittle is offline
http://store.makerplane.org/10-chann...r-mono-amx-2a/
http://54.162.78.90/redmine/documents/16
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 wings complete
Victoria, BC (Summer)
Chandler, Az (Winter)
Old 08-12-2015, 05:31 PM
Finley Atherton Finley Atherton is offline
I used the audio mixer above. Much cheaper than an Audio Panel and works very well.
My audio inputs are GTN 650, Icom A200, Skyview, Trio Propilot and a Sigtronics intercom.
Fin
9A
Old 08-12-2015, 05:45 PM
Ed, the kit version of that 25 pin mixer is only $75. But I don't remember if you are a homebrew electronics guy or not. It is small and detailed work, but easy if you have experience.
Old 08-12-2015, 05:46 PM
But I also need an intercom- the one I've got doesn't work well.
Old 08-12-2015, 06:02 PM
Walt's Avatar
Walt Walt is offline
pretty hard to beat either of these:
http://www.aircraftspruce.com/catalo...ges/gma240.php
http://www.aircraftspruce.com/catalo.../pma5000ex.php
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 08-12-2015, 06:22 PM
rv7charlie rv7charlie is offline
Before giving up on the existing intercom, can you supply more detailed info? Most simple intercoms tend to have one summing amp for all the mic inputs, with perhaps another amp for the radio input.
What kind of noise do you hear (hum, buzz, roar, etc). Does it do it with nothing plugged into either mic jack? With only the pilot mic plugged in? If you plug in both headsets (both mic & ear) and switch to isolate (where the pilot phones are quiet, right?), do you hear the noise in the passenger phones?
Charlie
