  #11
Old 08-12-2015, 10:58 AM
sblack sblack is offline
what is the point of putting an oops rivet in the hole in the spar? If it is on the tension side there won't be any increase in strength. Isn't the objective just to ensure the hole is clean with no cracks? Once you have done that what does filling in the hole accomplish?
Scott Black
VAF dues 2020
Instagram @sblack2154
Old 08-12-2015, 12:07 PM
clutch22 clutch22 is offline
Filling an open hole reduces the stress concentration at that location. Plugging a hole with a rivet will not allow the hole to deform in extreme loading situations and thus will be less likely to fatigue. Scott, I'm sure it would be fine to leave it open, but that's just what I would do with my airplane if I decided to fix it.
By the way, I agree Sam if you decide to replace that spar. It would be easy. I would go ahead and cleco the dimpled skin to the holes so that everything is match drilled. I know the prepunched holes are accurate, but it can be annoying when rivets don't want to seat all the way in the dimple because holes don't want to align 100%.
Oh yeah, and I don't like hearing about dimples being flattened. It reminds me of bending a paperclip a few times...
Sam, did you ever hear back from Van's?
Andrew Austin
RV-10
-Flying!
Old 08-12-2015, 01:26 PM
sritchie sritchie is offline
Hey guys,
I gave Van's a call this morning; the engineer at builder support recommended that I file the hole out to the edge of the crack, make a little doubler that captured this dimple and a rivet on either side, dab a little proseal on the crack before squashing it then just proceed. That should stop any crack propagation.
Haha, as has happened every time I've called builder support, the tone was very much "This happens ALL the time, and there's no way you can just trash a part every time you run into something like this." If it were earlier in the process I'd probably have just ordered a new one right away, as I said, but it's really good hearing this from the Van's.
So! That's the plan. I made my doubler this morning, filed the hole out to the end of the little cracked piece, and everything is nice and rounded now. No crack, and the doubler should provide the extra metal for strength.
Thanks all for your advice!
Old 08-13-2015, 09:39 AM
bill@fusion4.net's Avatar
bill@fusion4.net bill@fusion4.net is offline
Originally Posted by RV7AJeremy View Post
If you have already dimpled the skin, I would just drill the spar to final size and dimple it. These pre-punched kits are extreamly accurate.
Like most others, I would replace the part; helps me sleep better at night for realitavly little money.
Plus 1 for this.
Bill Thomasson
RV-10 - Flying - Phase II. 99.8% done... it's never really done!
http://sites.google.com/a/fusion4.net/rv10/
Suwanee, GA.
Old 08-14-2015, 08:24 PM
The Wizzard's Avatar
The Wizzard The Wizzard is offline
Default 2 rivets
you can clean up the hole and put a rivet on both sides of it as well if you have the clearances.
Dave Cicciari
3 Paper Airplanes and counting, Honorary "President of The United States of Love"
Dues Paid
