Go Back   VAF Forums > RV Firewall Forward Section > Alternative Engines
Old 08-08-2015, 09:55 AM
hlangebro's Avatar
hlangebro hlangebro is offline
Default Franklin 6 cylinder 205-220hp
I am curious if anyone has considered a Franklin 205-220hp for their RV project?
I have a 160hp 320 and I cruise along at 162ktas, however the Franklins are in production and are still pretty affordable and lightweight.
The 220hp version has a dry weight of 297lbs, vs 285 for the 320 and 295 for the 360 and 320 for the IO-360.
There is a company who supposedly is developing a FFWD kit for the 7 with a Franklin:
http://www.franklinengines.com/rv7.cfm
It would be interesting to see how much it would cost, and a Whirlwind C/S prop on top of that and cruise speed could increase by 20-25ktas and climb more than double!
H?kan Langebro
San Diego, CA
RV-7A, slider
Lycoming O-320 D1A, 160hp C/S
First flight 6-11-13
Re-engineering a Lancair 320..!
http://www.youtube.com/watch?v=AJuQ68tccTQ
http://www.mykitlog.com/hlangebro/
Old 08-08-2015, 10:05 AM
Naigool Naigool is offline
Default Injection?
It seems to be only offered with a carburetor... Not really modern!?
Old 08-08-2015, 10:10 AM
rv9builder rv9builder is offline
If I remember correctly, the factory put a Franklin in an RV-8 about 15 years ago. I think they called it "Franklinstein!"
Mark
RV-12iS Fuselage
RV-9A Project: Sold
VAF donation made for 2020
Old 08-08-2015, 10:23 AM
Low Pass's Avatar
Low Pass Low Pass is offline
It was the original configuration for the RV-8 prototype.
Bryan
Houston
Old 08-08-2015, 11:17 AM
digidocs's Avatar
digidocs digidocs is offline
I have a fair amount of experience flying behind a Franklin on a Stinson 108. Super smooth, great sound, and *very* easy to start. If parts support is good, I wouldn't hesitate to buy one.
David
Old 08-08-2015, 11:25 AM
N427EF N427EF is offline
The low compression "super smooth" puts out 165 hp.
and the high compression 10:1 220hp PZL produced in Poland is
eh, well.. "not so smooth".
You lose your mogas option on a 10:1 comp engine and you are definitely
limited to carbs or pressure carb.
My friend has about 300 plus hours on his 220hp RV-8 with Ellison throttle body.
He is pretty happy with his choice.
Ernst Freitag
RV-8 finished (sold)
RV-10 Flyer 600 plus hours
Running on E10 mogas
Old 08-08-2015, 11:29 AM
hlangebro's Avatar
Default Franklin
It is only carbureted as far as I know. TBO is 1500, which is reasonable. There is a Velocity at my airport (Ramona, RNM) and he has a either a 205 or 220hp Franklin with a IVOprop, and it is super smooth and very fast. I think he cruises along at 180-190ktas.
I think it would be an interesting option. I did the weight and balance for mine, and I have the longer engine mount, however it falls well within the CG range, although at a slightly higher weight due to engine and C/S prop.
Food for thought..
H?kan Langebro
San Diego, CA
RV-7A, slider
Old 08-08-2015, 11:37 AM
N941WR's Avatar
N941WR N941WR is offline
A friend built an RV-8 with the Franklin 220 HP engine and loves it!
He is trying to sell it has he currently has an RV-12 and is working on an RV-14.
Contact me, if you are interested.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 08-09-2015, 11:10 AM
Toobuilder's Avatar
At first glance, the 220 Franklin seems like a good choice for the -14. Light, inexpensive, and high power.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 08-09-2015, 01:52 PM
g zero g zero is offline
Default Franklin
At a second glance not so much . We had a Kit Fox wth a Franklin at the airport last year . Full of issues with piston fit , leakage , overheating , after 40 hours it was removed . Not sure what it was replaced with .
Rv8
N 666 TA
First Flight 2-3-2015 🚀
2017 donation paid
