Old 08-07-2015, 10:09 AM
Xkuzme1's Avatar
Xkuzme1 Xkuzme1 is offline
Default Horsepower vs Vacuum Pump
There is a part of me that is considering eliminating the vacuum system on my -4. Would that be a noticeable power increase by removing the vacuum pump? What is the vacuum pump worth in horsepower? I know it wouldn't be a lot, but maybe 5-7 horsepower.
Thoughts?
X
RV-4 - 0-320 (160HP)
www.KCFlight.org
Tinker
ATP/CFI/II/MEI
N617TN
Old 08-07-2015, 10:20 AM
SHIPCHIEF SHIPCHIEF is offline
I doubt that much, maybe less that 1 HP? although the whole pump & vacuum system can weigh 10 pounds, which is worth getting rid of...
Ditch the pump, and go EFIS w/ engine monitor plus an airspeed indicator and an altimeter.
I wish I had done so more completely.
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
2019
Old 08-07-2015, 10:29 AM
AltonD's Avatar
AltonD AltonD is offline
Whatever I saved, I null'd it out when I replaced it with a vacuum pad driven B/U alternator.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 08-07-2015, 10:33 AM
Jordan1976 Jordan1976 is offline
One way to estimate is to look up the wattage of an electrical driven vacuum pump. The Aero Safe guardian draws about 200W of power.
A horsepower is 746W, so 200W is 0.27 HP.
Of course there are other efficiency differences, but it's not likely that the one on your engine draws 4 times that. So it's less than 1 HP.
