Replaced during the required prop strike inspection?
The crank the first thing to go, from what I have read. I don't recall hearing of a cam being damaged during a prop strike but I suppose it could happen. Case halves can also be damaged/cracked in the process.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
