Old 11-21-2006, 11:21 AM
kentb's Avatar
kentb kentb is offline
Unhappy Oil leak from the oil return line
I have found a small amount of oil leaking from around the oil return line from the head on three of the four lines. It looks like it is the blue fitting that goes into the head. I will be checking the other fitting (the one on the pipe) tonight, but if I need to tighten the one on the head, how do I do that?
I would guess that I will not be able to rotate it 360 degrees. Do I remove it and used some kind of sealing compound with it?
Kent
Kent Byerley
RV9A N94KJ - IO320, CS, tipup
AFS 3500, TT AP, FLYING....
Canby, Or
Old 11-21-2006, 12:10 PM
Allen Barrett Allen Barrett is offline
It's possible that the AN 823-6D (blue fitting) can indeed be turned 360 degrees. However, check and see if the flare on the end of the turbe has been damaged by overtightneing of the nut first. If this is not the case, and tightening of the fitting is required, use gray anti-seize. Work the fitting in a couple of turns and then back out a turn, back and forth until the fitting is secure. Works for me.....
Allen
Old 09-14-2013, 10:54 PM
Rosie's Avatar
Rosie Rosie is offline
Location: I live in on the Rosamond Skypark (CA) and am married to Victoria (Tuppergal).
It took me four iterations of working the very same oil return line (I thought it was the rubber line that connects to the sump), but I FINALLY found a very small crack in the bend.... Here's my temporary "It's o-dark thirty and I have to fly in the morning" fix Rosie
Paul A. "Rosie" Rosales
Rosamond Skypark (L00), CA
RV-6A, 4200+ hours since 7/4/2000
