The play is mostly the result of the u-turn bend that is in the fwd end of the cable.... because there is some clearance between the center cable and the outer housing, there is room for the cable to slop back and forth within the housing.
It is normal and has been proven in service and during a GVT flutter evaluation to not be a problem. The system should still be properly maintained to keep the play as small as possible (avoid play at the trim tab connection, etc.)
Scott McDaniels
Hubbard, Oregon
