Old 08-02-2015, 01:57 PM
Jrskygod Jrskygod is offline
Default Fuel Pump Overpressure
Yesterday while taxing for departure the lady in the EFIS started complaining about fuel pressure. It seemed to be intermittent and I have had this indication at times before. The EFIS would read 7.5 to 8.0 # then after a bit the pressure would go back down to much lower numbers. I thought the problem was a faulty sender as the engine didn't care. Anyway yesterday after I flipped on the boost pump for takeoff the lady started complaining about the pressure again but as the power came up the pressure fell to about 7# and she shut up. I did a couple of circuits of the field. Every time power was reduced the pressure would go up and hold at 8# or so until I powered up then it would reduce.
I know how these LW 15472 low pressure pumps work as the actuator spring is the pressure regulating device so I decided to put a mechanical gauge on the fuel system. I just knew the problem had to be a faulty sender. To my surprise the mechanical gauge and the EFIS read within 1/2 # of each other. With just the mechanical pump on the pressure was generally around 7.5# and when the boost pump was turned on it jumped up to a little more than 8#.
I had always been told that there was no way for the system pressure to build that high because of the way the pump was designed. I do know now that that is just not true. The pump has less than 400 hours on it and I have a new one on the way. I never had a problem with this before I upgraded the panel and the plane was not flying for about 6 months. The pressure before always was in the 2 to 3# range and sometimes would fall below 1# for a short period.
Perhaps some folks out there in Van's land have an explanation for this abnormal behavior as I have never heard of a spring getting stronger, just weaker with time. I sure can't think of another explanation.
RV-3 Rebuilding
RV-9 Flying and having fun, experimenting and having fun, did I mention flying and having fun?
RV-6A SOLD
Maule M5-235C SOLD
C-172G SOLD
Stinson L5 SOLD
Grumman AA1A SOLD
Old 08-02-2015, 02:40 PM
petehowell's Avatar
Default Very Hot?
Was this on a hot engine? Long taxi? See this thread with references to pneumatic lock.
I have seen some high FP in these situations. No idea if this may be what happened to you. If the engine was not hot, I doubt this is the culprit.
Pete
Amateur Radio - KD0CVN
Doggies Delivered - 25+
St. Paul, MN
Old 08-02-2015, 04:45 PM
Nope cool engine and short taxi from hanger. OAT was about 88 deg. F. and I use 100LL fuel always
RV-3 Rebuilding
RV-6A SOLD
Maule M5-235C SOLD
C-172G SOLD
Stinson L5 SOLD
Grumman AA1A SOLD
Old 08-02-2015, 05:35 PM
petehowell's Avatar
Default Ignore me.....
Clearly I was wrong - let us know what you find!
Pete
St. Paul, MN
Old 08-09-2015, 08:55 PM
Default Fixed the problem!!
Bolted the new pump on Friday evening and went up yesterday. All is well again with pressures normal. The ambient temperature was around 100 deg. and I not only did a climb to 10500 and set up for cruise but also did some low level and pattern work. The pressures were perfectly normal in all regiments.
I really wanted to disassemble the pump and try to figure out what was causing the high pressure situation but that $100.00 core charge made me box up the defective pump for return.
The moral of the story is - yes these pumps can and are able to provide excess pressure. I would have never believed it unless it happened to me. So beware if you have excess pressure. It might not be a faulty sender after all.
RV-3 Rebuilding
RV-6A SOLD
Maule M5-235C SOLD
C-172G SOLD
Stinson L5 SOLD
Grumman AA1A SOLD
