Originally Posted by Larry DeCamp
Bill,
I used 320 wet for all blocking and feathering. The waterborne Stewart primer is prone to pinholes if sprayed too wet and rather porous if applied drier and thin .
If I get any fact based insight on Stits vs West micro and Stewart waterborne I will update the post.
SuperFil is bisphenol-A epoxy and microballoons, just like epoxy and microballoons mixed at home. Although there are certain convenience aspects, it's a expensive way to use dry micro.
Cured and sanded micro should be sealed before primer. Remember, it is mostly hollow glass (or phenolic, if dark red) spheres, which are cut open by sanding. In addition, a certain amount of air is entrained while mixing, and the air bubbles also form pinhole voids when exposed by sanding.
There are primer-surfacer-sealer products (look up PPG K36 and K38 for example), which are urethane primers with a high filler content (usually talc). Most users have found it takes more than a few rounds of spraying and sanding to get a pinhole free surface. Since micro is commonly used to surface fiberglass, and the fiberglass also needs sealing, I use a skim coat of plain mixed epoxy, sand without breaking through, then shoot epoxy primer , then the primer-surfacer wet-on-wet for blocking. Search the archives.
Epoxy skimmed micro over glass, custom air intake:
Skimmed cowl exit panel:
Sanded without cutting through the epoxy seal coat, first coat of epoxy primer:
