View Poll Results: Did you explore aft CG/gross weight handling in your RV in a test flight(s)?
I built my RV, and I explored aft CG/weight combinations during phase one
43 |
54.43% |
I built my RV, and I did not explore non-typical CG/weight combinations
6 |
7.59% |
I purchased my RV, and I explored aft CG/weight combinations during phase one
10 |
12.66% |
I purchased my RV, and I did not explore non-typical CG/weight combinations
4 |
5.06% |
I like bacon.
16 |
20.25% |
07-31-2015, 11:10 AM
Do you explore the flight envelope of your new RV?
So the thread about a landing incident at Oshkosh is super interesting from several aspects. One in particular is the discussion around how our stubby-winged aircraft handle differently at higher AoA and weights.
During phase one testing, that portion of the flight envelope should be explored in some detail. Indeed, I had a couple of cards devoted to it. However, phase one typically applies only to the original builder. Does transition training touch on it?
The transition training I received didn't explore this area of the envelope, but it did equip me for doing so. I'm wondering how many purchasers (vs. builders) have explored their RV's envelope?
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
07-31-2015, 11:14 AM
A perfect opportunity to take advantage of the grossly underused EAA Flight Advisor Program.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
07-31-2015, 11:22 AM
YES! I found it amazingly helpful; many thanks to Mike Hilger who acted as both my tech counselor and flight advisor!
07-31-2015, 11:26 AM
I haven't but then I just bought my RV-8. However I do have the book:
Flight Testing Homebuilt Aircraft
by Askue, Vaughan
I'm studying the book and starting to plan a flight test program. Not because the plane is in any Phase like Phase 1 but because I want to thoroughly understand my airplane.
Flying RV-8 N880BC
2019 Dues - happily paid.
07-31-2015, 11:34 AM
I've given some transition training in my RV, and concentrate on slow flight, steep turns, stalls, and power off landings. Most homebuilts, like RVs, have 'simple' wings (no washout, no taper, no airfoil changes) which have 'sharper' stall characteristics than most certified planes. Crossed control stalls are often rather eye opening
Flying at various CG positions depends on the plane. Some, like mine (side by side) are difficult to load to the CG limits (without exceeding a weight limitation). Getting to gross weight is easy, so that is definitely done.
Dennis Glaeser CFII
Rochester Hills, MI
RV-7A - Eggenfellner H6, GRT Sport ES, EIS4000, 300XL, SL30, TT Gemini, PMA6000, AK950L, GT320,
uAvionixEcho ADSB in/out with GRT Safe Fly GPS
07-31-2015, 12:13 PM
Even though I have 1500+ hrs in my RV, every year before Osh I go up with the airplane "loaded to the gills" but without the wife. I do an hour or two of flying around at 70-80 knots following some local railroad tracks at 1K AGL, I also throw in some stalls for good measure. I do this just to brush up on my own slow flying skills as they do tend to get rusty. I encourage the folks that go in our group do the same prior to the trip.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
07-31-2015, 01:48 PM
...and tight right-hand patterns!
Dan Horton
RV-8 SS
Barrett IO-390
07-31-2015, 02:56 PM
I will, it is on my test cards, but until first flight, i like bacon.
Bill
RV-7
Lord Kelvin:
07-31-2015, 03:19 PM
Should option three read "I purchased my RV, and I explored aft CG/weight combinations during phase TWO" rather than phase one?
If so, that's me. I didn't put the plane back into phase one.
RV-6 | O-320 | Triple-bladed Catto
07-31-2015, 03:51 PM
Good catch - yes, it should.
