Old 11-21-2006, 04:22 AM
Bateleur Bateleur is offline
Question Recommended Reading
Hi everyone,
I'm one of what I'm sure must be thousands of RV wannabee's out there. If everything goes according to plan, I'll be ordering my RV-8 kit in the latter half of next year. (Here's to hoping the "Fastback Dilemma" is a thing of the past by then!!! ) I've done the Info pack and the preview plans are on their way!
In the meantime though, I'm researching as much as I can and plan to setup an appropriate workshop between then and now. Whilst I will endeavour to maintain the absolutely pristine environment that Rudi does, I think I need be realistic too! (i.e. I know myself... ain't no way! )
What I'm doing right now though is reading, reading, reading and more reading... (this has been a looooong time comming... a huge step was finally settling not only on an RV, but ultimately the -8 too). With all that being said, I'd like to know what y'all recommend as pertinant and relevant reading when it comes to building RV's. Anything you guys (and gals) think makes for good reading, please let us know. Obviously that is besides these awesome forums and all the other brilliant builders' sites on the net.
Thanks in advance...
Old 11-21-2006, 05:58 AM
pierre smith's Avatar
Default 43.13
Welcome Gary,
One of the most recommended and quoted manuals is an FAA publication; CAM 43.13. This manual covers all of the accepted aircraft assembly and maintenance practices as approved by the FAA. Many consider this to be the Aviation mechanics' Bible.
Regards, (I'm originally from Kempton Park!).
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 11-21-2006, 06:01 AM
Ironflight's Avatar
VAF Moderator / Line Boy
If you haven't already found it, there is a Yahoo group for the RV-8 that goes back a number of years, and although the archives are horrible to search, skimming through the topics of those several thousand posts will give you a good handle on many of they key issues.
It's a bit of a slog, but since you're not building yet, if you spend several hours every night reading, it will help you to build the schedule discipline you'll need when your kit does arrive!
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 11-21-2006, 06:40 AM
You will need to get spun up on the certification process. A good place to begin is at
http://www.faa.gov/aircraft/gen_av/u...amateur_built/
The Regulatory Support Division, AFS-600, at one time published a booklet titled "AMATEUR BUILT AIRCRAFT REFERENCE MATERIAL". It was a complete guide to certifying your airplane. My copy is 1997 and dated, but it may still be in print if you can find it. I picked it up from the FAA at OSH. Your local FSDO may have it. You need to get connected with them anyhow. Usually there is one guy assigned to amatuer building and he will set up a file on your project.
dd
Old 11-21-2006, 07:05 AM
Thanx for the welcome!
I've been searching for CAM 43.13 and so far have found a gazillion references to it but not the publication itself... will keep digging!
Thanks for the heads-up re the RV-8 yahoo group... just joined and it looks like it's pretty active! I'll definitely be wading through that one!
With reference the FAA specifically, I've already started going through what would be required by our local (South African) CAA with regards regulations. Also chatted to local builders and have recently joined the local online RV Club.
What I'm really looking for though are books and the likes... if it's on the net, chances are I'll find it. Which books come highly recommended though... something that I can sit down and devour from cover to cover whilst not at my PC! Anything from building techniques to test flying (Sheet Metal for Planks, The Nutcases Guide to Engines and Airframes, Avionics and Instruments by G. I. Suck... ), anything!
Of the topic related books in your bookcase, which has served you the best... which one would you recommend?
Wooohooo!!! My preview plans arrived whilst I was typing... 'scuse me for a few days will you!!!!
Old 11-21-2006, 08:26 AM
Mel's Avatar
Mel Mel is offline
If you will be using a standard aircraft engine, I highly recommend "Sky Ranch Engineering Manual" by John Schwaner.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 11-21-2006, 09:02 AM
bsacks05's Avatar
bsacks05 bsacks05 is offline
Aviation Mechanic's Handbook published by Aviation Supplies & Academics. Quick and easy reference for electrical, drawings, conversions, hardware, tools, fabrication, plumbing, metals. Plus much more. All info, no B.S.
Bruce Sacks
RV-9 N659DB - Flying since 7/1/06
Hatz CB-1 - Fabric covering with Polyfiber.
Warner Robins, GA
A&P
APRS KJ4EFS
Old 11-21-2006, 09:06 AM
Pirkka Pirkka is offline
Even you have selected what to build, this is pretty good book about kit planes overall:
Kit Airplane Construction by Ronald J. Wanttaja
http://www.amazon.com/Kit-Airplane-C...dp/0071459731/
PS. Van's sells it for $18.50.
Pirkka
- RV-7 -
Tail: Waiting for fiberglass.
Wings: Some priming left, then lot of riveting.
QB Fuse + Finishing kit: in crates.
Old 11-21-2006, 10:22 AM
Rick6a's Avatar
Rick6a Rick6a is offline
About the best RV specific publication you will likely find is "24 Years of the RVator." Within its pages you will find a wealth of information and building tips some of which were written by fellow RV'ers who have "been there, done that." Over the years, Van has compiled the best of the best in articles and information and combined that material into this very informative reference work. As you build your RV, you may want to refer to its pages and read how other builders handled a given task or what Van recommends. http://tinyurl.com/ydy6d6
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 11-21-2006, 10:44 AM
Patrick1244 Patrick1244 is offline
You can buy the publication at wicks. Here is the link.
http://www.wicksaircraft.com/catalog...be3aafb3a85f83
