Old 07-30-2015, 09:38 AM
danielabernath danielabernath is offline
Default Water in fuel somewhere-interesting ride this AM
I went up in RV 12 that has been sitting in Florida for a few months (Its a long story).
Removed 2 l/2 tubes of water from sump and then tried to fly.
But she sputtered so we aborted the flight. (me and CFI Rhonda Colburn-a wonderful person and CFI).
So I did another drain underneath at the sump.
We went up with nose up and she balked. Would not get to more than 4400.
I and she heard a 'bang'.
I gave her the plane and she got us back on the ground.
We noticed that when nose is down she shoots to 5500. We did 5500 on final.
When nose pushed up, then sputters and gets down into the 4400's.
Once on the ground I did another fuel check and found nasty brown stuff (NOT much) on the bottom of the tube.
I have 2 a and p men working on it Saturday.
What do you think?
Picture of W.S. in N262WS
Old 07-30-2015, 09:53 AM
tomkk's Avatar
tomkk tomkk is offline
I guess I'd suspect water in the tank. If it were me, I'd hold the tail down, turn on the electric pump and drain out of the gascolator until empty.
Tom
Port Orange, Fl
EAA #51411
RV-12 N121TK ELSA #120845; first flight 06/10/2015; 700 hrs as of 02/2020
RV-12 N918EN ELSA #120995 Eagles Nest Project; first flight 05/18/2019
SPA Panther N26TK; First Flight 03/13/2020
Old 07-30-2015, 10:17 AM
DonFromTX's Avatar
DonFromTX DonFromTX is offline
By holding the tail down, the water would all run to the rear of the tank and hide there. Not sure why you would want to do that. Seems like lifting UP on the tail would be better for getting the water out.
A&P, PP-SEL, Pathological Flier, EAA Technical Counselor
EAA Chapter 595 President,http://www.595.eaachapter.org/index.htm
Retired US Army Officer
Old 07-30-2015, 10:21 AM
wirejock's Avatar
wirejock wirejock is offline
Default Stale gas
Maybe it's not just water. Gas gets pretty funky when it sits too long. 3 months is usually not long enough, but you shouldn't get brown stuff. Stale gas stinks too. Easy to identlfy.
Sound like a carb cleaning is due as well.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 07-30-2015, 10:25 AM
Mel's Avatar
Mel Mel is offline
You didn't say what kind of fuel. Auto or aviation. Aviation fuel holds up quite well for several months and even years. Auto fuel, not so much.
I would suggest draining the entire system and flushing out lines, then refill with fresh, or at the very least, filtered fuel.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 07-30-2015, 10:46 AM
It is auto fuel. Smells like auto fuel when in tube (and spills on my arm)
Old 07-30-2015, 10:50 AM
tomkk's Avatar
Ooops, yeah my mistake. I was thinking the outlet was at the rear but, you're right, I had it backwards.
Tom
Port Orange, Fl
EAA #51411
Old 07-30-2015, 11:00 AM
Mel's Avatar
Mel Mel is offline
In that case, I would drain and flush the system, filter the fuel and put it in my car mixing a little at a time with fresh fuel.
Put fresh fuel fuel in the aircraft.
Old 07-30-2015, 11:07 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Auto fuel most likely has some alcohol in it--------and water and alcohol mix rather well.
I second Mel's advice----------drain, flush, and refill.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 07-30-2015, 11:10 AM
DonFromTX's Avatar
100ll goes to heck also. I had my Ercoupe sitting in a closed very hot hangar for several months, and it would just barely run after sitting that long. I mixed a lot of fresh 100ll with it and it decided to fly at least, still not too happy.
