Old 07-28-2015, 02:07 PM
Dan Langhout's Avatar
Dan Langhout Dan Langhout is offline
Default Garmin GDL-39R Mounting Location
This question is really for the G3Xperts. Is there any problem mounting the GDL-39R ADS-B receiver right next to a 1090ES transponder? I know the antennas require some separation but what about the actual units?
Dan Langhout
2020 =VAF= Dues PAID . . . . .
RV-7 N528DP slow build
First Flight July 26th, 2014
665 hours and counting . . . .
Now based at Moontown (3M5)
Old 07-28-2015, 05:25 PM
g3xpert's Avatar
g3xpert g3xpert is offline
Post
Hello Dan,
The emissions from a Garmin transponder are low enough that there should be no problem locating the GDL 39R next to the transponder.
The only potential concern, which we are sure you have considered, are cooling air for the transponder.
You might also check the performance of the Bluetooth antenna inside the GDL 39R in the chosen mounting location (if you care).
Let us know if you have additional questions.
Steve
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
Old 07-28-2015, 07:41 PM
Thanks for the response and info!
Dan Langhout
