Originally Posted by davidkarlsberg
I bought a semco gun off ebay to do my tanks. Vans sells proseal already in the tube. You just mix it up and insert the tube in the gun. Each tube of proseal also comes with a little nozzel you screw in.
Thanks David, but the cost is rediculous. MUCH cheaper to mix from the quart can and put in the disposable cartridges. Also, you reduce waste since you can only mix and use what you need for that work session.
