Old 07-27-2015, 11:02 AM
bkthomps bkthomps is offline
Default Static Buildup and Trim Indicators
This past weekend I ended up flying into my airport just behind a passing thunderstorm/lightning, as I was descending into the yellow arc, I noticed my Ray Allen Trim indicators (which incidentally, have been INOP and needing replacement) start to light up brightly, as I gained speed they glowed brighter and brighter
I got a few hints of static on the radio, but all the other electronics kept trucking along, and the only other strange indication was my AMMETER showing a -21AMP discharge (volts were positive and fine)
My question is this, is there anything I can do better in terms of wiring or shielding to prevent static buildup to certain components? Has anyone else dealt with static during a flight and has tips to share?
Old 07-27-2015, 12:12 PM
bill@fusion4.net's Avatar
bill@fusion4.net bill@fusion4.net is offline
Default Trim indicators
Have not had any problems, but if you are in need of new RayAllen indicators I have 3 that can be had for a very good price at LZU.
bill at fusion4 net
Bill
Bill Thomasson
RV-10 - Flying - Phase II. 99.8% done... it's never really done!
http://sites.google.com/a/fusion4.net/rv10/
Suwanee, GA.
Old 07-27-2015, 12:55 PM
Raymo's Avatar
Raymo Raymo is offline
AFAIK, the only thing you can do for static build up is to install static discharge wicks. All the composite airplanes seem to use them.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 07-27-2015, 02:22 PM
Yeah, there is some debate over that however. A good bit of the newer composites are forgoing them, I just want to be very informed and educated before I enter my next scenario like this if that makes sense, and since I'm still building my RV-7, I wanted to poll the audience here on VAF
