Tom, dimpling the nut plates is good for this situation where you are already halfway there (dimpled skin), but you should get some -3 NAS1097 rivets for future nut plates. You can use the NAS rivets, flush, with no work to the nut plate even in .025" material. 5-6 rounds with the deburring tool is sufficient for the heads. This will save you many many hours over the build. I guarantee that you will like them after you do a few. Easy to drill out just like standard rivets.
I don't like using my expensive dimple dies on steel parts.
Only Vans calls them "oops", and Vans has the -3 and -4 in stock, but don't list them. I got -3-3, 3.5, and 4 solely for installation of nut plates. The -4 sizes are for oversize hole mistakes. (oops!)
Bill
RV-7
Lord Kelvin:
