Originally Posted by Mel
This might be OK for short periods, but normally a wood prop should always be left in the horizontal position. Wood has a lot of moisture content and leaving the prop vertical causes the moisture to migrate toward the lower tip throwing the prop out of balance.
Good evening Mel,
I firmly believe that with the finishes on todays propellers, the position of the prop will have no appreciable effect on balance when the engine is ran on a regular basis. This is true as long as the finish is good and the plane lives inside of a hangar. I agree that all wood has a moisture content, but if there was enough moisture inside of the prop to migrate then it would be physically impossible to keep a three bladed prop balanced. I have almost 5 years and over 500 hours on my prop and do not have any issues with balance.
I did learn in A&P school about how to position a prop, but keeping in mind that was put into the text books when when props had brass leading edges and drain holes in the metal leading edge.
I am not trying to start a big argument on this subject, especially in the current thread and I do respect your opinion and knowledge.
Curtis
