Old 07-25-2015, 08:13 AM
guido99 guido99 is offline
Default Hole in wheel pants
There is no hole in my wheel pants to check tire pressure. So the only way to check pressure is to remove pants check pressure and reinstall pants. What a pain!!
Does anyone have dimensions to help locate these holes along with hole size?
Thank You in advance !
Guido
Old 07-25-2015, 08:34 AM
Measure the distance from the center of the axle nut to the valve stem. That gives you the dimension to offset the hole in the wheelpants from the screw hole where the pant attaches to the axle nut or axle nut spacer. I think I used 7/8" holes and plugs, but larger would make things easier.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 07-25-2015, 08:57 AM
jay bell jay bell is offline
Default Tire pressure inspection hole
Hi Guido
A laser pointer works well to locate the hole. With the pants off, aim the pointer at the correct angle to reach the tube stem. Then install the pant without moving the pointer or the plane, and mark your hole location on the pant.
I eliminated the tire pressure inspection hole for a few reasons:
-new butyl or "air stop" tubes don't leak like the old rubber tubes, and seldom require topping up
-I can determine correct tire pressure by running my finger between tire and bottom of wheel pant. I built the pants with a finger width tolerance to the tire, so if the pressure is low, the gap is too narrow
-I pull the pants at 50 hour intervals to check the brakes anyways; and check pressure at that time (they don't leak)
- if I change my mind, I can always add holes later
Jay
RV7-A
C-FXPT
IO-375, Catto, Electroair, Skyview
530 hours
Old 07-25-2015, 09:37 AM
BillFear BillFear is offline
Default We were going to add them
Finally decided it was not needed, agree that good tubes solved the problem for us. Pretty much just adjust air pressure at conditional time or anytime we have the wheel pants off.
Bill Fearheiley
Lake Norman, NC (14A)
RV7a N705RP (no longer own)
Contribution in for 2017, money well spent
