Old 07-24-2015, 01:57 PM
ethand ethand is offline
Default Fuel Flow Transducer & VPX
What is the general consensus for wiring the fuel flow transducer to the VPX? I have one pin left in my VPX Pro and trying to decide if it should be used for the fuel flow transducer or some other lighting etc functions with the fuel flow powered from an aux bus as described in the VPX manual.
E
Old 07-27-2015, 05:29 PM
maus92 maus92 is offline
My Red Cube gets power from the Garmin G3X system GEA-24 engine and airframe sensor module. There is no connection directly from the VP-X to the fuel flow sensor, at least in my case.
CA
2000 RV-8A | O-360, SDS CPI, FP, G3X Touch, VP-X, EarthX | Eastern Shore | KESN
Old 07-27-2015, 05:43 PM
Brantel's Avatar
Brantel Brantel is offline
I agree.. Engine sensor power is typically provided by the EMS box.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 07-27-2015, 10:04 PM
Thanks for the replies.
I see the transducer power and ground in the GEA-24 pin out now that I know.
E
