Old 11-20-2006, 12:53 PM
backpacktheworld backpacktheworld is offline
Default Is the Empennage on the RV-8 the same as on the RV-7 & -9??
Does anyone know if they are the same?? I got the tail kit for the RV8 and was wondering if its a done deal or is the option still open.
Old 11-20-2006, 12:55 PM
Jamie's Avatar
Jamie Jamie is offline
Default Nope
No, they are not the same. I think the only common part is the vertical stab and *maybe* the elevators. The h-stab and rudder are definitely different. This is for the -7.
On the -9, EVERYTHING is different from the -8. The rudder from the 9 and 7 kits are the same.
Old 11-20-2006, 02:58 PM
N941WR's Avatar
N941WR N941WR is offline
The easy way to tell is by the part number. If it starts with a "6", it is from a -6. "7" for the -7, etc.
On the -9 many of the parts are the same as the -7 and -6 and only those parts unique to the -9 start with a "9".
Hope that helps.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 11-20-2006, 10:18 PM
mike crowe mike crowe is offline
Default 8 TAIL KIT VS 7 AND 9
As an instructor at Alexander Tech Center on the Tail kit program I can tell you;
The 8 and 7 elevators are the same. The rudder is only for the 8. The horiz. is the same between the 7and 8 except for the skins and two angles. the vertical is the same between the 7, 8, and 9 except the 9 skin is thinner.
Mike Crowe
McDonough GA
RV8A
Old 11-21-2006, 05:17 AM
burgundyja's Avatar
burgundyja burgundyja is offline
Default is it for sale?
IF SO IS IT THE 8 OR THE 8A AND DOES IT HAVE THE ELETRIC TRIM OPTION?
