Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
Old 07-23-2015, 06:40 AM
TXFlyGuy TXFlyGuy is offline
Default Garmin GTN-650, or GTN-750?
My neighbor (C-206) advised to go with the GTN-750. We were planning on the GTN-650 to go with our G3X Touch. Any thoughts from you fly boys?
Old 07-23-2015, 07:31 AM
Auburntsts's Avatar
It depends on what features are important to you. IMO if you have an EFIS to display the moving map full time, the 750's advantage over the 650 isn't worth the extra AMUs. If I had steam gauges and the money then I'd opt for the 750. YMMV....
Truth in lending - I have a dual screen G3X with a 650.
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 07-23-2015, 07:46 AM
chazking's Avatar
chazking chazking is offline
Default AFS & 650
I have AFS 5600s & GTN-650. The moving map on the 5600 has good screen real estate, making it easy to view. The 750 has the advantage of using a full keyboard & decent screen real estate. The cost for maps & plates from Garmin is high relative to others, e.g., Seattle Avionics.
Cost for AFS (or others) and a 650 is lower than the combined cost for all Garmin. In the end it may come to a matter of personal preference and familiarity.
Ch?z King
Old 07-23-2015, 09:21 AM
GTWreck GTWreck is offline
Default Rarely touched
I have a G3X (non-touch) with a GTN-650. I only use the 650 to input my flight plan and to select instrument approach procedures. I have a couple user data fields on the screen that I like to reference that aren't available on the G3x. Aside from that, those are basically the only two interactions I have with the 650's touchscreen; everything else is done via input to the G3X.
The 750's full screen keyboard would be nice, but not really a necessity for me. And given that Foreflight and Garmin Pilot can now transfer flight plans to your 650/750 via FlightStream, I'm not sure that the bigger screen is worth the extra $$$.
Aaron Sims
RV-10 (2015 Bronze Lindy)
RV-6A (sold)
Home Field: Mallards Landing (GA04)
Locust Grove, GA
Old 07-23-2015, 11:06 AM
That is good advice. Thanks.
Old 07-23-2015, 01:31 PM
Brantel's Avatar
Brantel Brantel is offline
The cost for IFR updates is high period for any IFR Navigator. You can thank Jeppessen for that...
The cost for a year of updates for the G3X is $149.99.
Apple's to apples, the Garmin G3X Touch system package pricing is similar or even a couple hundred less than the competition. Not to mention that most of the time they offer deals when the GTN is packaged with the G3X system.
OP:
If money is no problem, go with the 750. If you have a budget, go with the 650. I have a 2 screen Touch panel and a 650 and they work beautifully together. It is like cheating!
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 07-23-2015, 01:40 PM
Here is the GTN-650 paired with the G3X...
Old 07-23-2015, 01:46 PM
M McGraw's Avatar
M McGraw M McGraw is offline
Default G3X and GTN 650
OP:
Brian,
Is that yearly subscription (149.99) for both the G3X and the GTN?
Marvin
Marvin McGraw, 5TN4
RV-14. #140039 Complete
Flight hours: 500+
2020 Dues Paid
The Dues Paid note is a reminder for me
Old 07-23-2015, 01:54 PM
Brantel's Avatar
No sir.
When you add the IFR Navigator to the mix, the price goes way up. They have a Pilot Packs available that do combine both in one subscription.
What I do is only update the Navigation database on the GTN650 as needed and keep the current maps charts and plates on the G3X updated. Works out better for my situation.
If you have a GTN750, and you want charts and plates on that big beautiful screen, the way I do it won't work.
Old 07-23-2015, 02:34 PM
M McGraw's Avatar
No sir.
I will probably do it the same as you.
Marvin McGraw, 5TN4
Flight hours: 500+
2020 Dues Paid
