Old 07-22-2015, 01:07 PM
Bevan Bevan is offline
Default Strange Oil pressure indication
I have the Vans mechanical oil pressure guage and VDO sender. It seems to indicate correctly until engine shutdown. On shut down, it steadily moves up to indicate max pressure ( >100lb ). Is this an actual pressure indication or some kind of plumbing/wiring error? The transducer is mounted high on the firewall and the pressure line was bled right to the sender.
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 07-22-2015, 01:42 PM
tim2542 tim2542 is offline
Default You sure?
You sure it's a mechanical gauge? If so it won't have a sending unit, just plumbing to the gauge. I'm guessing it's really an electric one and the needle is just floating around when no power to it.
One thing for sure, you don't have any pressure when the prop stops.
Tim
Old 07-22-2015, 01:46 PM
I meant to say the gauge is analog (as opposed to digital). It has a needle that swings mechanically but it is electrically operated (using a remote sender). Yes, there is no pressure on shutdown and I would expect the gauge to indicate that.
Bevan
Dual P-mags
Grand Rapids EFIS
Old 07-22-2015, 01:51 PM
Raymo's Avatar
Raymo Raymo is offline
I agree with what Tim inferred. You probably have an issue relating to related wiring / grounding. A poor ground can manifest itself in strange ways.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
