Ran into an interesting situation over the weekend while performing my annual maintenance/inspection. I had order eight new NGK DCPR8E spark plugs from Aircraft Spruce back in April. When I installed them Saturday, I discovered that the caps on the ends would not screw off. Actually ruined one plug trying to remove the cap.
As we all know, the Rotax 912ULS plug wires will only accept the small diameter threaded stud when pushing the boot onto the spark plug. The cap is too large to fit in the connector inside the boot.
So, I laid out an old spark plug and new spark plug side by side to see what gives. The part numbers are identical; yet the new plugs are unusable with their permanent caps.
What am I missing here? Anyone else have a similar experience?
NGK's park number for the ones with the removable nut is 4339. Yours are probably 4179. Both are DCPR8E. I made the same mistake a while back when buying the NGK BR8EIX.
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Reason: incorrect data now corrected
NGK 4339 are Removable terminals
NGK 4179 are Sold terminals
I will correct my post for the archives.
Sorry for the confusion.
Bevan
Dual P-mags
Grand Rapids EFIS
