Look at this picture if you would please:
http://rvflying.tripod.com/fuel1.jpg
This is the small fuel line instead of the called out longer one. My issue, the instructions call a 45 degree fitting to come out of the carb. If I use that, the fuel line passes right over the exhaust. The 90 degree fitting parallels the exhaust but still is within an inch. In addition, as you can see in the picture, the fuel line make a 90 degree "curve" that "just ain't right". More here, the firesleeves rubs the engine mount which will not viabrate.
Suggestions or "ID'ers"
Could someone please post a link showing there fuel line run from the mechanical fuel pump to the carb.
I need to get this firewall forward stuff done as the painter just called to say he painted the flying surfaces BLACK over the weekend!!
