Old 07-18-2015, 09:44 AM
Saville's Avatar
Saville Saville is offline
Default How to find and buy a parachute?
Ok so now that I have the airplane, I need a parachute.
I need a chute for me (195lbs) and a chute for the pax. Typically the pax will be my girl and she's little - 5' 4" 115lbs.
I don't know how this is done and have a number of questions:
1) If you contact a parachute company, is it delivered to your home?
2) Is it delivered as a kit? Is some assembly required?
3) Is it delivered packed or do you have to get it packed?
4) Are chutes one size fits all? If not, if I get a chute for my girl, then that means I need another one for someone larger?
Any info is appreciated.
Flying RV-8 N880BC
2019 Dues - happily paid.
Old 07-18-2015, 10:07 AM
az_gila's Avatar
az_gila az_gila is offline
Thumbs up
They should come packed and ready to go.
For help in selection and a view on the weight recommendations go to a glider supply place...
http://wingsandwheels.com/parachutes.html
As an example - here are the Paraphernalia makers suggested numbers -
*Mini = Recommended Pilot Weight is up to 240 lbs.
*Micro = Available in 180 lbs. and 240 lbs. versions.
*Wedge = Available in 180 lbs. and 240 lbs. versions.
*Long = Available in 180 lbs. and 240 lbs. versions.
*Seatpack = Recommended Pilot Weight is up to 240 lbs.
If you live at higher density altitudes you might want to build in a bit of margin, but MA should be OK...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 07-18-2015, 10:21 AM
jbDC9 jbDC9 is offline
A good place to start looking is Don Mayer's Parachute Shop, http://www.parachuteshop.com
I bought a Strong 304 seat pack from him, works well in my RV-8, T-28 or T-6. The Strong 314 looks to be geared towards the RV-4 and 8, but for other RVs, you might look at a backpack type. One thing that caught my eye are the prices, oh my how they've gone up! Mine was $1500-ish in 2006; today it would be $2250. Ouch.
If you buy from a vendor like this, it arrives in a big box, ready to go. No assembly required, it has a current pack, just pull it out of the box and strap it on. To be legally usable the chute needs a fresh repack every 180 days by a certified rigger. Look around for a sport drop zone, they'll have guys that can do it.
As far as sizing for your girl, call the vendor, they'll know best...
You might also find a decent used one on Barnstormers; if you go that route you'll want to get a fresh inspection and repack right outta the gate methinks.
John Bixby
RV-8 QB sn 82030 - 1750 hrs
O-360-A1D/CS/Pmags
Houston, TX
Old 07-18-2015, 10:26 AM
Tbone's Avatar
Tbone Tbone is offline
Default Cost?
How much does it cost (average) to get it re packed?
___________
Terry
RV7
XP IO360
Old 07-18-2015, 10:36 AM
az_gila's Avatar
Exclamation
If you by a used one be cautious of it's age.
This note is from Butler Parachutes -
Age Limits: Because most aging effects in nylon textile products cannot be detected without destructive testing, BPS will not pack a parachute that is over twenty years old at the time of repacking.
Gil Alexander
Old 07-18-2015, 11:02 AM
wilddog wilddog is offline
You need to try different types in your plane to see what is comfortable and fits. I'm paying $60 for repack at local skydive place. Needs repack every 180 days to keep FAA legal. If you buy a new one the dealer/rigger can give you expert advice.
Old 07-18-2015, 11:21 AM
GaryChatelain GaryChatelain is offline
Default Private message sent
I sent you a private message regarding a parachute.
