08-07-2015, 07:23 PM
So, do we have any guidance on installation of the new positioning source? My RV-8A is currently in pieces, so it's convenient for me atm to install the (expensive) antenna either under the cowl, or on the deck just aft of the rear seat without much trouble. How long should the RG400 conductor be? I can make it 3ft, but I've seen "recommended" lengths much longer...
CA
2000 RV-8A | O-360, SDS CPI, FP, G3X Touch, VP-X, EarthX | Eastern Shore | KESN
08-07-2015, 07:26 PM
The new Rev. U install manual on the web covers GMC 307, GPS 20A, and GSU 25B
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
08-07-2015, 07:39 PM
"U"? I'm glad I don't print out every new version. I'm still working off a hardcopy two or three versions ago.
CA
08-08-2015, 07:12 AM
Transponder upgrade still needed?
I have a standard 330 transponder, will the new GPS20a work with this or do I still need to upgrade it to ES. Also will the 20A provide ADSB in to my 696 or is the 39 still required.
Also any chance this unit can connect to the GRT HX efis as an external GPS?
Thanks!
Bill Fearheiley
Lake Norman, NC (14A)
RV7a N705RP (no longer own)
Contribution in for 2017, money well spent
08-08-2015, 07:47 AM
Thanks!
Hello Bill,
You would need to upgrade your GTX 330 to a GTX 330ES before connecting it to a GPS 20A would provide ADS-B Out.
The GPS 20A is a WAAS/GPS position source, but not an ADS-B receiver, so you will still need the GDL 39 to provide dual frequency ADS-B traffic and weather to your 696.
Not only does the GPS 20A provide ADS-B+ position data to the Mode S transponder, but it also provides a second RS-232 port that provides NMEA data at 9600 baud, 1 start bit, 1 stop bit, 8 data bits, and no parity and transmits GPRMC, GPGGA, GPGSA, GPGSV, GPVTG, and PGRMT sentences for use by other devices. Not sure if your EFIS will use this data, but it might.
See page 22-41 of the Rev. U G3X Installation Manual for a description of this RS-232 connection.
Steve
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
08-08-2015, 07:50 AM
Thanks!
This GPS does nothing for providing your 330 xponder with the ES functionality. You will still need that upgrade if you want to use the 330.
This is a GPS not an ADS-B IN receiver. You will still need a receiver and I highly recommend the dual band GDL39 unit. Works like a charm with the 696!
Garmin has stated that this GPS could be used with other systems as it will support their ADS-B+ format which has already been at least partially deciphered by a few and hopefully Garmin will publish that protocol eventually and it also outputs NMEA data as well.
EDIT: Looks like Steve beat me to it. So there you have the official answer!
08-08-2015, 07:51 AM
Thanks steve
I currently have my 696 feeding gps data to GRT as a backup so I assume this stream would be useable.
Bill Fearheiley
08-08-2015, 08:00 AM
If it were me, I'd hardwire the GPS-20A to the GRT and use the 696 as a backup GPS source if an extra RS-232 was available. But I'm weird and enjoy changing things around and rewiring....
CA
08-08-2015, 08:05 AM
Forgot to mention i have 300xl connected to grt as primary gps, 696 is number 2. I would keep that as i can feed a flight plan to AP from either GPS.
Thanks all for great answers!
Bill Fearheiley
08-08-2015, 02:00 PM
GPS 20A Antenna Cable Length
Hello Charley,
Good question on the RG-400 length requirements. As hard as we try to catch everything, it seems we left that guidance out of the GPS 20A installation guidance in the Rev. U manual.
The GPS 20A has the same antenna installation requirements as the GTN 6XX/7XX as explained below.
Cable loss from the GPS/SBAS antenna should be between 1.5 dB and 6.5 dB in order to maintain proper rejection to interference signals.
Coaxial connectors and adapters, such as TNC to BNC, add additional loss to the cable and should be considered when computing the cable loss. A typical loss of 0.2 dB can be used for each connection.
For RG-142B or RG-400, 1.5 dB equates to a length of approximately 6.5 feet of cable with a connector on each end.
For installations where you don't need 6.5 ft of cable, the cable may be coiled, taking into account the minimum bend radius of the cable.
Let us know if you have additional questions.
Steve
Garmin G3X Support
g3xpert@garmin.com
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
